Author Topic: Dyna s static timing  (Read 2046 times)
Offline johnyvilla
« on: April 04, 2010, 09:48:25 PM »
I am having issues static timing my dyna s and 3ohm coils on my 836 rebuild. I just want to make sure I have everything right.
My left coils top screw is conected to the blue wire and right to the yellow. The  black\white wire conects to each of the bottom screws. I connected the ignitions red line to my rear brake switch and yellow and blue lines connect to their coresponding colored wires.
When I try to statically time with the coils colored wires and a ground, the light just stays on regardless of the crank position.
Am I missing something?
Re: Dyna s static timing
« Reply #1 on: April 04, 2010, 09:57:38 PM »
I don't know anything about dyna ignitions, but if it doesn't have points, I'd be willing to bet you can't static time it with a light....
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #2 on: April 05, 2010, 02:09:41 AM »
why not the magnetic trigger act in exactly the same matter, magnet on the crank goes over the switch it closes (making the coil fire) and when it passes it, the switch opens (breaking the connection).  You might want to make sure your advance is working properly and that your cam tension is proper as well.
1975 CB750K
Project Back in Black
Offline w1sa
« Reply #3 on: April 05, 2010, 03:44:17 AM »
Per Dyna S instructions, continuous light when setting timing indicates a wiring conx problem.
First off, make sure you've got switched 12V to the Red wire going to the Dyna S unit.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: April 05, 2010, 04:45:54 AM »
I found an installation guide here:
http://www.mpsracing.com/instructions/Dynatek/DS1-1_1-2.pdf
As w1sa said, you need 12v to the red wire, I wonder if it's simply a matter of picking up on wrong side of brake switch?
btw, I really hate those splices like illustrated in that guide. At least a crimp connector or soldered joint is best imo.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #5 on: April 05, 2010, 05:23:32 AM »
I think Frostyboy is right. You may be hooked to the down stream side of the brake switch. See if the static timing light goes off when you apply the brake. The bottom primary coil terminal , along with the black/white wire, is a better place to attach the ignition's red wire. The kill switch will shut down the coils and the ignition modules.
Stu
MCN DTF
Offline johnyvilla
« Reply #6 on: April 05, 2010, 07:15:36 AM »
Yup. Light goes off when peddle is pressed. Time to do some un-soldering.
Thanks
Offline johnyvilla
« Reply #7 on: April 05, 2010, 12:43:57 PM »
That did the trick. I was able to get the 1-4 time statically to the advance mark, but the 2-3 coils are firing between the f and the advance mark. Apparently other people have had this problem before.
Should be good enough to get her started.
Offline Frostyboy
  • Circa 1951
« Reply #8 on: April 05, 2010, 01:30:38 PM »
If you open that link I posted for the installation guide, read step 5 on page 3. That should tidy up the timing for 2 &3.
Cheers.
« Last Edit: April 05, 2010, 10:13:13 PM by Frostyboy »
We haven't met yet.
[CB550F1]
