Hi everybody! Allow me to introduce myself, as this is my first post. My name is Tim, and I'm relatively new to your forum. I am in the U.S. Army, fixing Blackhawk helicopters, and I'm currently deployed to Iraq (though I'll be home in 2 weeks). Before I joined the Army I had a '72 CB500 that I had neither the time or money to finish, nor the guts to tear apart for fear of forgetting how to put it back together. You can see here that she was a beat up old gal who needed a lot of loving:
http://s230.photobucket.com/albums/ee291/Lavis325CL/1972%20Honda%20CB500/ She was my first project, and I wish I hadn't sold her because now I know she wasn't as far from done as I had thought since I had her running. Alas, shoulda-woulda-coulda.
Anyways, onto present day: about 2 months ago I found a nice '73 CB500 on ebay, and the guy happened to be driving towards my home town for a flea market. I picked up Sally for $600 and free delivery! The history on the bike is incomplete: the speedo says 50k some miles while the owner claims actual mileage closer to 23k. The speeo doesn't look original to me - it looks like one off of a 550 of a 500T. That also turned my eye towards the headlight ears and turn signals, which seemed different to me. The only ones I had seen before were the style where the signal stem screwed into the end of the ear to secure the headlight bucket. I preferred those, so I'll be swapping them out. The bike came from the man's son who bought it off of a junk car dealer/friend of theirs. He had the bike running in less then an hour in 2003, rode it all summer, then she sat in Minnesota until I bought her. Here is how she looks now (pics thanks to my parents):
http://picasaweb.google.com/TimValis/20100220TimSPhotosOfCB500# http://picasaweb.google.com/TimValis/20100220KrisPhotosOfCB500#There's a lot of rust on this old gal, and I know I'll be replacing a lot of hardware. I plan on tearing the whole bike down to the frame and just doing a full resto from the ground up. Here is a list of things I plan to do to her:
-See if engine runs (I already know that this will require replacement of the coils)
if so: change oil and run with 75% oil, 25% diesel in the crank case as well as adding seafoam to the gas to clean engine, flush and fill with oil again
-Clean the engine, considering paint/lacquer?
-Open engine, clean gently
-Strip bike down to bare frame
-Coat with acetone/whatever chemical necessary to begin removing factory paint, then media blast to finish.
-Paint frame, swing arm, and triple tree clamp. Considering either Eastwood gloss black chassis paint or duplicolor engine paint gloss black
-Replace rear shocks
-Possibly replace front forks?
-Flush front forks
-Replace all 4 turn signals and headlight ears
-Clean all (non engine) hardware, replace as necessary
-Replace all engine hardware
-Clean engine, exhaust, and all chrome
-Possibly clear coat for chrome such as wheels or exhaust?
-Possibly drop in 650 cam?
-Rebuild and buff carbs
-Replace spokes
-Replace chain/sprockets (play with sprocket sizes?)
-Replace tires/tubes (continental tires - RB 2/K 112 conti-twins)
-Flush and bleed front brake line, rebuild master cylinder/caliper as necessary
-Replace all cables
-Inspect rear brake?
-Replace speedo (not original?)
-Move ignition key to under frame (personal preference)
-Paint/coat tank and sidecovers Candy Jade Green (YES, I know the original color is Bacchus Olive, but I just can't resist the Jade
-Replace coils/wire/caps/plugs
-Buy new sidecovers (
http://lpmreplicaparts.com/honda/CB500F/sidep.html)
-Replace seat
-Replace rear brake lens cover
-Replace air filters
-Replace all fuel/overflow lines
-Rebuild battery (It's new, but the previous owner let it sit for 2 months without a charge in the cold, and now it can't hold one. I'll be emptying it of electrolyte and frying it soon to clean the plates.
So, since this is my first ORGANIZED project - even though it's my second time tearing into a bike - how does my list look? Is there anything else I should add? Any advice you guys would give is greatly appreciated. I'm just trying to prep so that when I get home I can jump right into this. I'd like to see if I could finish in time to enjoy the end of the TX riding season in October.
Questions I have in advance: What kind of media do you recommend for blasting the frame? Is there any preference/leader in engine hardware? Does anybody offer some kind of a clearcoat I can use to protect the chrome of my exhaust (since I know they have a tendency to rust through)?
P.S. I apologize for only posting links to albums, but my internet over here is slow and cuts out often, and uploading/attaching pics isn't exactly a luxury I have at the moment. Anyways, thanks in advance for all the help!
