Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - Hopefully Good!?  (Read 253793 times)
Re: 1978 CB750K - Running - Riding/Break in — Third time's a charm
« Reply #1050 on: October 03, 2016, 02:32:07 PM »
If not, you might want to opt for these.  They will allow you use significantly more torque on the head.
« Reply #1051 on: October 03, 2016, 02:45:15 PM »
THANK YOU MCRider!!! Greatly appreciated
Shoot. I forgot all about this. Still need the info?
Couldn't hurt...but now that I am committed to pulling the engine again...I will have the cam cover off and hopefully have an easier time cleaning out the old crap in there
OK
Offline SKTP
« Reply #1052 on: October 03, 2016, 03:04:28 PM »
Studs are stock...
http://cbrzone.com/sohc.html
Hrmmm...$90...you think it would make a big difference? I am on the no leak quest!!!!
Do you have to split the cases to change the studs?
« Last Edit: October 03, 2016, 03:07:18 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1053 on: October 03, 2016, 04:02:58 PM »
Studs are stock...
Could be. Could introduce another frustrating variable as well...
But if you have stockers that have been torqued multiple times, they may be fagged out.
« Reply #1054 on: October 03, 2016, 04:23:39 PM »
It eliminated a leak on my stock 550 and my rebuilt 836.
Offline SKTP
« Reply #1055 on: October 03, 2016, 04:28:32 PM »
I think I am just going to try the gasket and sealer (as recommended in Hondaman's book) + put all the O-ring and dowel-pins back in. The leak can be temporarily stopped with rope...it's can't be that major of a leak....(I hope)...that way is 2 weekends. New Studs is Months for me unfortunately
Don, you get to come over and lift! ;) - but seriously, let's go for a ride!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1056 on: October 03, 2016, 04:44:21 PM »
I might have an extra set.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #1057 on: October 04, 2016, 04:20:03 AM »
You might consider thread sealer on the valve cover bolts too. Most of the valve cover bolts have bottomless holes, so if oil makes it "halfway" past the valve cover gasket to the bolt, then oil can weep out the threads of the valve cover bolts. I read this somewhere and had to verify for myself that most of the valve cover bolt holes are indeed bottomless and are exposed to the atmosphere.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: 1978 CB750K - Running - Riding/Break in — Speed Chart confirmation?
« Reply #1058 on: October 04, 2016, 04:53:00 AM »
Thanks
Lester mags. 19" front 18" rear. Powder coated black. And I want to say Dunlop D404s.
Wheels look great! Can I ask where you got them powder coated and approx cost? Thinking of doing the same.
And I am appreciating the dream of a leak-free bike - we share the same dream!
Thanks
Andy
Offline Restoration Fan
  • My wife will never call me
« Reply #1059 on: October 04, 2016, 11:57:56 AM »
I HIGHLY recommend going with stronger studs.
We used the APE studs on Stella and when you hold them up beside the stock studs, there is a very noticeable difference in thickness and sturdiness.
So far, I've put over 2,000 miles on Stella and she's still leak free.  *knock on wood*
Offline SKTP
« Reply #1060 on: November 18, 2016, 10:16:23 AM »
Third time is a charm. I plan on pulling my motor on Thanks giving weekend and if I am really lucky, get it back in again.
I am replacing my BASE, HEAD and Cam cover with NOS/OEM Honda gaskets as well as putting the all the dowel-pins and rubber o-rings back in. (I used an MLS gasket last time and have some leaking)
I also bought all new Clutch plate as I was experiencing some slip and I have no idea how old the current plates are.
So if I have all the o-rings and the 3 main gaskets for the top-end and the clutch gasket...Am I forgetting anything? I think I will risk re-using the tensioner gasket.
I will also follow HONDAMAN's book to a T and use sealer were he says to...You can pull the motor with the oil pan on right?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1061 on: November 18, 2016, 10:45:32 AM »
Yep. I even leave the cam tunnel cover on too. I usually remove the carb overflow guide bracket from the back of the motor (next to the rear crankcase vent) as well as the exhaust studs (later style) or spigots (early style) though.
TAMTF...
Wilbur
Projects:
« Reply #1062 on: November 18, 2016, 05:06:34 PM »
Oh, yeah, the oil filter housing comes off too!  ;)
TAMTF...
Wilbur
Projects:
Offline 01Thomas
« Reply #1063 on: November 19, 2016, 02:35:21 PM »
those 6 Pucks!
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline SKTP
« Reply #1064 on: November 21, 2016, 11:32:01 AM »
I have 300 miles on those 6 pucks (sealed with Permatex form a gasket 2)...I figured they'd still be OK...or should I replace them since I am in there?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1065 on: November 21, 2016, 01:15:47 PM »
Ordered New ones...will measure thickness...heard some are too skinny
thanks
BOOKMARKING
What is Nil's contact info?
http://www.restocycle.com/
« Last Edit: November 22, 2016, 06:02:51 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1066 on: November 27, 2016, 10:17:58 PM »
The motor is out
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1067 on: November 28, 2016, 10:34:40 AM »
just a few reminder pics...I am now thinking that getting the top of the cylinder resurfaced would be a good idea. The Head was resurfaced. I will be using OEM Honda gaskets this time and applying HONDABOND where HONDAMAN's book says to...and putting all the dowel pins and gaskets back in. (last try was MLS, yes I know I should have had everything resurfaced now). I did need to remove the Oil pan to get the engine out the side. We tried with it on...no way it was going to clear.
Looks like it leaked from these 2 allen-hean bolt valve-cover bolts (as well as the head gasket):
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1068 on: December 09, 2016, 10:35:54 AM »
Sending Jug to APE to be resurfaced...merry Christmas to me
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1069 on: December 09, 2016, 12:17:25 PM »
Check the flatness of the valvecover on a piece of glass..  Might have to work it down a bit with sandpaper on the glass..
« Reply #1070 on: December 09, 2016, 01:39:14 PM »
Or maybe those screws were a skosh too long and bottomed out in their holes?
Offline Tintop
« Reply #1071 on: December 09, 2016, 01:54:40 PM »
Are there copper or alloy washers under those bolts??
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #1072 on: December 09, 2016, 05:22:28 PM »
There are four under the cover on a 750 that need a copper washer to seal... do they have that washer?
That could cause a leak.
Branden's leak free top end thread would be a good one to consult...
http://forums.sohc4.net/index.php/topic,107040.0.html
Give it a read.
You are on the road to getting it leakfree.
Hondaman has mentioned some issues with aftermarket top end kits oring sizes.  May want to look that up. Have to google search it, as the forum search is dead.
There is a sticky about using the Google search on the forums.
Offline SKTP
« Reply #1073 on: December 14, 2016, 12:07:12 PM »
What part number are we talkign here?
« Last Edit: December 14, 2016, 12:09:08 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1074 on: December 14, 2016, 01:12:48 PM »
That only applies to the "F" models, and then only the 77/78. SKTP is workin' on a K model...
TAMTF...
Wilbur
Projects:
