Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - not good  (Read 247701 times)
Offline willbird
Re: 1978 CB750K — Tell me about your 836cc experience
« Reply #1400 on: April 24, 2024, 11:16:39 AM »
Thank you for the reply PeWe but all of that is way over my head...I want to just drive the bike somewhere and have them tune it....
Apparently this guy is good: https://cohenmotorsports.com/dyno-tune/ (he's the $600 guy)
But Southern California people, who do you recommend?
Mickey gets that ($$$$)as he is a very talented tech and mostly because the HD guys that go to him have bulging pride and deep pockets to bolster their pride.
Mickey used to handle all of the Triumph media fleet and was Triumph's go to guy to get answers to their problem bikes.(until he pissed off a new guy above him in corporate that didn't know him and what he knew.)
A great guy to be sure. Talk to him before you commit.
If he is buried in work at $600 he should give $700 a try probably :-)
« Reply #1401 on: April 24, 2024, 01:29:11 PM »
I spoke with my dyno guy (Rick Stetson) today. Full dyno tune EFI 600.00
 Carburetor bikes 500.00
Offline SKTP
« Reply #1402 on: April 24, 2024, 03:50:57 PM »
Thank you MRieck
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1403 on: April 25, 2024, 01:57:35 AM »
So far so good...
Good to hear and boy are those Cyber trucks ugly!
They make a Volvo 240 look good... Haha
« Reply #1404 on: May 06, 2024, 11:42:50 PM »
Mickey Cohen is the man as to Triumphs.
Offline SKTP
« Reply #1405 on: May 29, 2024, 01:55:17 PM »
Over 200 miles so far...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1406 on: May 31, 2024, 07:11:22 AM »
Looks great!
Offline SKTP
« Reply #1407 on: July 31, 2024, 09:37:56 AM »
Oil pressure.
So when I start my bike up (I have an oil pressure gauge just above the points cover) the bike get full pressure fairly quickly.
Then it randomly drops really low quickly a few times during warm-up.
Once the bike is warmed up, the pressure appears to act normally.
The actual Oil pressure light never comes on again once the bike is running.
Is this normal?
I am installing a CYCLE-X rebuilt oil pump because it is freaking me out.
« Last Edit: July 31, 2024, 10:13:07 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline BenelliSEI
  • 1969 cb750
Re: 1978 CB750K — Post 836 OIL PRESSURE
« Reply #1408 on: July 31, 2024, 10:00:51 AM »
That usually indicates the by pass valve is opening on the pump, and then closing again. How high does it go initially? What weight oil are you using?
« Last Edit: August 01, 2024, 04:40:37 AM by BenelliSEI »
« Reply #1409 on: August 01, 2024, 12:50:36 AM »
I have seen oil pressure warning blinking when idling a few minutes, bike on side stand.
Opened the oil cap and saw very low oil level, almost nothing. Pump filled a little that engine needed direct.
The angle of bike was not good for oil pump to fill tank with oil.
After that, no more warming up parked on side stand.
Happened both my CB750.
« Reply #1410 on: August 02, 2024, 05:02:39 PM »
I've seen that happen when the seal between the 2 halves of the pump is getting hard and the engine is cold. After it warms up the oil returns faster to the tank from the sump: I'm imagining the seal gets more flexible with the heat, so the suction side of the pump gets more efficient(?). Replacing the seal(s) in the pump makes it stop doing that, which was how I pondered up this diagnosis.  ???
Offline SKTP
« Reply #1411 on: August 03, 2024, 10:10:50 AM »
Thanks guys...I will be replacing the pump very soon.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1412 on: October 18, 2024, 10:54:59 AM »
Life has been busy...I have the new/rebult oil pump from Cycle-X and I am installing a 2002 Ducati Monster oil cooler...those are the Ducati lines for mock-up.
I plan on ordering the new lines next week. Need to get back on the road!
I think I can custom make a bracket that will allow the horn to still fit, turned 90 degrees
« Last Edit: October 18, 2024, 10:56:45 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1413 on: November 13, 2024, 10:41:25 AM »
Almost there!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
Re: 1978 CB750K — Post 836 OIL PRESSURE — Not good
« Reply #1414 on: November 16, 2024, 03:11:43 PM »
On Thursday night my friend and I swapped in the Cycle-X oil pump and tightened down all the new oil-cooler lines and started the bike for the first time since all of this oil-cooler stuff began. The bike fired right up and the oil pressure read 60lbs and stayed steady. There had been an issue with the pressure dropping and and then going back up while warming up. I was hoping that this new oil pump would solve that issue. We finished the pump install and oil-cooler installation fairly late, so we were content with is just running, seemingly really well, on the center stand. We could see the oil returning strongly through the oil tank hole and the pressure gauge read 60lbs steady.
So today I finally had time to test drive the bike. I checked the dip stick, the oil wasn't on the stick but I know that I put in 3 liters/3 x 1.05 quarts. The idea was to get it totally warmed up then add oil to account for the new capacity from the cooler and lines. I warmed it up on the side stand and the pressure gauge read 60lbs steady. I guess that I warmed it up for 2-5 minutes? No issues. I took off down the street and got a taste of how much fun this bike is as an 836cc.
I went 0.3 miles (GPS TRACKING) and the pressure light came on (red light) I looked down at the pressure gauge, and out was zero. I pulled over and turned off the bike.
I pushed it home 0.3 miles and checked the dip-stick. It had some oil on it.
The end. I am bummed.
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm
Everything seemingly ready to go:
Pressure during warm up:
Red pressure light on:
Oil on stick after pushing/failed test drive:
« Last Edit: November 18, 2024, 12:34:54 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline BenelliSEI
  • 1969 cb750
Re: 1978 CB750K — Post 836 OIL PRESSURE - not good
« Reply #1415 on: November 16, 2024, 04:47:38 PM »
That just sucks! If we assume there is nothing wrong with your pump or the built in oil pressure relief valve, the only thing that can cause that sudden loss of pressure is no oil?
When the bike (and you) have totally cooled down, is there any oil left in the tank? Could the return line from the scavenge side of the pump to the tank be collapsed internally or twisted and kinked? If the engine is sucking oil faster than it gets returned to the tank, this could be a cause of zero pressure…….
« Last Edit: November 16, 2024, 04:50:32 PM by BenelliSEI »
« Reply #1416 on: November 16, 2024, 11:03:20 PM »
Is the oil hose to the oil tank plugged or can collapse?
Correct amount of oil is filled?
3.5 Liter in a dry engine, 3L for an oil change.
I could get sudden low oil level when checked after 30-60 minutes ride. Less than half on dipstick. No oil lamp warning.
Returned home to see full.
I also swapped oil pump to discover the same sudden low.
Changed oil hoses and swapped pump again, back to the most restored one.
Have not seen the issue after that.
The replaced oil hoses were not old, not cheap aftermarket. Expensive aftermarket.
The newer ones from a guy in Germany that repair old oil hoses. My K2 has used a set since it was restored. No issues.
I'm happy that I bought 2 sets last time. Still have a set to a CB750 build.
Engine inside and pump screen very clean.
« Last Edit: November 17, 2024, 10:14:08 AM by PeWe »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1417 on: November 17, 2024, 06:44:24 AM »
I hate to say it
Something sloshing around and blocking the pickup screen?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #1418 on: November 17, 2024, 07:29:34 AM »
Sounds like the pan needs to come off and pull the pump.  Last cb750 I worked on that never made oil pressure, we never figured out after trying everything.  Ended up swapping to a complete different bottom end after trying everything.  While swapping the stator cover we found where all the oil was going, there and the trans.  Still don't know why.  The faulty bottom end was also found to have one extremely worn rod bearing.
     Also worked on a cb360 with no oil to the top and was traced to a broken gear drive shaft pn the oil pump, so this needs to be checked thoroughly that the gears and shafts of your pump are not damaged.
Offline SKTP
« Reply #1419 on: November 20, 2024, 11:07:30 AM »
So my mechanic thought about the symptoms and thought that the only reason this could be happening was because something going wrong inside the oil tank. So we swapped out the oil tank and removed the oil cooler from the equation for now. We then started the bike with the new oil tank.
The old pressure built up quickly and reach 80psi when cold. The bike warmed up and there was no weird pressure drop.
I rode the bike about 1.5miles and had zero issues.
Once warm the pressure was at 20psi at idle.
I will do more test drives close to home before re-connecting the cooler. Hopefully this was the issue!
I will call a Ducati mechanic and ask if there's any chance a 2002 Ducati Monster oil cooler is unidirectional in flow? Seems unlikely from how the cooler looks.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1420 on: November 20, 2024, 12:05:32 PM »
If the cooler has a temperature device (thermostat) like some of the old-timey ones did, it runs in bypass mode until the engine warmed up. If plumbed backward, though, it does what you've bee describing.
The oil cooler looks upside-down to me: if it has such a bypass, it would block the oil when hot. Normally the hoses are very short and come straight up into the cooler from the bypass plate on the filter housing.
..just my 2 cents...
