Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - Seems bad :(  (Read 281708 times)
Offline Vinhead1957
I would deflate. It fully spray a little silicon lube around the rim and then re-inflate
Offline Freaky1
If you mean the bead is not seated, a little off the rim yea, spray it and re inflate. If that doesn't work, deflate a bit and smack the tread with a rubber mallet, don't swing for the fences or let all the air out either.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline SKTP
It's like the rubber "pin-stripe" that should be all evenly away from the rim has been swallowed up by the rim presumably where it had been sitting...if that makes sense?
« Last Edit: February 13, 2013, 11:37:55 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
Wow that was harder than I thought but the rear brake is back on and working. Is it even possible to get the spindle part on without removing the cotter pin? My bike definitely was dropped on its right side by the PO. The right foot peg and the brake spindle parts are slightly bent. Had to rubber mallet the spindle its slightly bent and tough to get through the hole...anyways wow that took some time. None of the manuals have good pics or info on how the entire drum brake lever assembly goes together...What a hot Valentine's day
« Last Edit: February 14, 2013, 11:30:14 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
New hitch pins. Did not accomplish much today
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline racinchase
Man that thing is looking good!
“The right bike, the right day, the right road, I just pretty much feel at one with the universe. When I feel like I don’t fit anywhere or I’m lonely or I’m all screwed up in the head, I get on my bike and go for a ride and it’s like all of the sudden, I’m fixed.” – Indian Larry
1975 CB750 K
2009 R1
Offline SKTP
First test fit of the triple A pipes.
This is a 78k. Am I going to have to grind down that first lip?
The "half moon" should press into the header tube? Between the slotted outer and the smaller inner?
« Last Edit: February 17, 2013, 04:31:07 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 1978 CB750K resto- exhaust half moons on triple-A pipes?
« Reply #307 on: February 17, 2013, 04:42:59 PM »
I think those aaa pipes are designed for the ko-k6 style exhaust spigots...you need to get the exhaust spigots from k0-k6, they are just like a short little pipe(1-1/2 to 2" or so?) that screws to the head where your studs are, then your aaa headers slip over the spigot and clamp on.  Wish I had pics for you, hopefully someone will be along shortly with some.
Offline Dream750
« Reply #308 on: February 17, 2013, 05:26:49 PM »
I’m with Seanbarney41 as you need the earlier K0 to K6 exhaust spigots & mounting hardware, then it’s a bolt-on affair. Those are cool pipes!  ;)
Double click on pics for larger view:
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #309 on: February 17, 2013, 06:49:21 PM »
Yeah, I like those pipes too. Would be worth the effort (for me at least) to switch to the earlier spigot connectors. Those pipes are wicked cool...  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline SKTP
« Reply #310 on: February 17, 2013, 06:52:23 PM »
Thanks. So for sure the earlier spigots are straight bolt on?
The heads are the same? Who's selling a set?  :)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #311 on: February 17, 2013, 06:56:52 PM »
I'm PRETTY SURE the spigots will bolt up. I've got some spigots I can bolt up to a K8 head just to be sure. The studs would be removed and replaced with countersunk head machine bolts. I'll test fit tomorrow and report back, unless someone else can chime in here that has already done it. I've got a set of drag pipes earmarked for a future build that will require the spigot connectors as well.
TAMTF...
Wilbur
Projects:
« Reply #312 on: February 17, 2013, 07:04:19 PM »
Man where did you find that pipe ?
Offline SKTP
« Reply #313 on: February 17, 2013, 07:06:42 PM »
Thank you very much. I pray that it's just a straight bolt-on deal.
If I have to remove the studs I will cry.
Eagerly awaiting your findings and thank you again.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #314 on: February 17, 2013, 07:11:21 PM »
 You have to remove the studs, just double nut them, when they start to move, like 1/4 turn , wiggle back and forth...easier on the threads. Easy job to change to spigots,,
 Those pipes make me drool..
« Reply #315 on: February 17, 2013, 07:12:30 PM »
??? All of the exhaust studs I've encountered were painless to remove. I use the exhaust nuts, doubled up (flange to flange) and twist'em right out. Maybe I've just been lucky? In fact, my latest project (78 CB750F) had to remove the engine four times(!) chasing oil leaks and I removed the exhaust studs for cyls 1 through 3 each time to help avoid gouging the paint off the frame.
TAMTF...
Wilbur
Projects:
Offline SKTP
« Reply #316 on: February 17, 2013, 07:20:30 PM »
I was really hoping to not remove the engine again...but yes, I have to do it right. Will I need a pro to put the counter sunk nuts in?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #317 on: February 17, 2013, 07:23:32 PM »
No,no,no,no. The spigot flanges have countersunk holes. The engine does NOT have to be removed. The engine removal reference was to illustrate the ease with which the exhaust studs could be removed. Engine removal from the frame not necessary to convert to spigots.
TAMTF...
Wilbur
Projects:
« Reply #318 on: February 17, 2013, 07:25:41 PM »
 I would trade a near minty Mac chrome pipe with the right mounts for that one..
Offline SKTP
« Reply #319 on: February 17, 2013, 07:34:16 PM »
Thank you Madmtnmotors. Can't wait to see what you discover tomorrow. I have found the parts on eBay and am ready to throw down. I want this bike finished and I just gave the stock exhaust away to Ricky Racer. I'm greeting these pipes on this bike.
754, thanks for the offer but I waited almost three years to find these babies...found on eBay. But thank you for the offer. Do you have a set of spigots and or flanges for sale?
« Last Edit: February 17, 2013, 07:54:50 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #320 on: February 17, 2013, 07:51:23 PM »
Yeah i got spigots but be cheaper to buy in your country.. If you cant find let me know..
Offline SKTP
« Reply #321 on: February 17, 2013, 07:59:15 PM »
So I'd just remove the studs and the old style screws would just screw right in?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #322 on: February 17, 2013, 08:50:36 PM »
Without having these parts immediately available to touch and see, at the moment, I can think of ways to use the spigots with your exhaust studs...but it would probably be more hassle than just changing 'em out for the stock screws.  `The clamps would be the biggest tangle, I think.  Oh yeah...don't forget you are gonna need clamps.
« Reply #323 on: February 18, 2013, 05:06:25 AM »
They should. A few of the studs will be difficult to remove as the frame rails interfere with the swing of the wrench. But you should be OK.
Dig out any old gasket material and fit new gaskets before install of the spigots.
« Reply #324 on: February 18, 2013, 06:46:15 AM »
Here are the spigots you need and countersunk socket screws will be needed too. That's a fantastic exhaust and worth the extra work needed to mount it correctly.
You might find these cheaper, start a wanted thread in the parts section.
http://www.ebay.com/itm/honda-cb750-cb750k-four-exhaust-pipe-flanges-spigot-1970-69-71-72-1971-73-74-75-/370732088518?pt=Motorcycles_Parts_Accessories&hash=item56515abcc6&vxp=mtr
