So I got my cases "parts-washed" to take off the grime...there were really gross I spent about 4 hours with a spray bottle of Simple Green and a tooth brush and was not happy with the results I was getting...so 60 bucks later (also did my block and oil pan)...I am happy
I could not get that pin out that holds in the kick-started and I left that big bearing in...Will there be any kick issues? (I barely ever used it anyways)
as for the bearing, I should be able to spin it with my fingers right? It seems to be seized. Any special trick to popping that baby out. I was planning on smacking it but thought I'd ask first in case there's a chance of damaging the case?
Here's a before and after of the cleaning and the bearing in question...Painting soon then it will actually start going back together!
Before:
After:
bearing:
So chains and tensioners...they are expensive. Does anybody just sell the rubber wheels (on the tensioners) OEM? or do I have to buy 50 and 70 parts?
$200 seems to me the going rate for Primary chains. Do you agree? Are all years chains the same?
thanks SOHCers!
