Author Topic: '74 cb550 ... Noisy cam chain, eh?  (Read 18603 times)
cb544
Back together and charging...
« Reply #25 on: May 07, 2010, 10:41:05 AM »
I like the new tank but the old seat doesn't fit, and really doesn't look good at all to me anymore, albeit comfortable as a couch.  Finally got the carbs back on and the Start button sorted.
O yea- don't litter.
Offline Zaipai
    • My Home page
Re: '74 cb550 - no need for a name
« Reply #26 on: May 07, 2010, 04:20:05 PM »
Yea, I love those F tanks. I have the same issue, my seat does not fit. I ordered a new cafe seat cover and I am hoping to make it fit with some alterations..
GL..
.: Scott :.
« Last Edit: May 07, 2010, 09:54:55 PM by Zaipai »
Its my Avatar..
75 CB550F  |
cb544
« Reply #27 on: May 07, 2010, 06:25:10 PM »
Yea, I love those F tanks. I have the same issue, my seat does not fit. I ordered a new cafe seat cover and I am hoping to make it fix with some alterations..
GL..
.: Scott :.
Ahhhh.. that's what it is. I'll have to reread the FAQs.
New issue: I got quite a shock when I went to use the start button last... Seems like the wires are touching the casing/handlebars? I'm going to open it up tomorrow and check it out after I bang out the stock seat pan.
Offline Zaipai
    • My Home page
« Reply #28 on: May 07, 2010, 09:55:54 PM »
Yea. sure sounds like that is the problem. You may find its a pretty easy fix..
.: Scott :.
Its my Avatar..
75 CB550F  |
cb544
« Reply #29 on: May 08, 2010, 06:47:55 AM »
.: Scott :.
Thanks Scott- your build is lookin great btw!
traveler
« Reply #30 on: May 08, 2010, 08:31:29 AM »
Keep at it.....eventually, things will sort out.
~Joe
« Reply #31 on: May 08, 2010, 08:43:06 AM »
it's cheaper then a snap on or a matco .. and built better then a craftsman ..
i love love love this socket ... the hole at top is nice for putting a screwdriver through when/if you can't get the ratchet in there
http://www.amazon.com/Motion-Pro-Spark-Socket-Wrench/dp/B001DDABGG
Offline Zaipai
    • My Home page
« Reply #32 on: May 10, 2010, 05:41:17 AM »
Thanks.. I am liking it so far. Some one on our block said it kinda looks like a bike version of a stock car, I guess I can live with that.. ;)
So did you get everything sorted out?
.: Scott :.
Its my Avatar..
75 CB550F  |
cb544
« Reply #33 on: May 10, 2010, 02:20:37 PM »
Do Kerker 4-1 exhausts require the use of the stock split flanges?
I've torqued the nuts way beyond specification, replaced the gaskets, and still have a series of major leaks...
traveler
Re: '74 cb550 - gettin there...
« Reply #34 on: May 10, 2010, 03:39:27 PM »
My advice...waht I have done inthe past....
Put a drip pan under it and work on the rest of it.....give yourself time to stand back and think about it....then little by little address the leaks....you'd be amazed at how doing this will work itself out! ;)
It's a 30+ year old bike.  Short of a complete nut and bolt restoration, it is going to have quirks and character. ;D
Keep smiling.....at least she runs! ;)
~Joe
Offline Zaipai
    • My Home page
« Reply #35 on: May 10, 2010, 04:25:33 PM »
Don't know for sure, however my Mac 4 into 1 do require them and the gaskets..
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #36 on: May 11, 2010, 06:39:55 AM »
be careful with that my man ... breaking a stud off in the head is a serious nightmare
cb544
« Reply #37 on: May 11, 2010, 01:59:45 PM »
Luckily I got out all of the studs... unfortunately, the bike came to me with one stripped hole in the block... Where can I get a proper Heli-coil? and replacement hardware, including those OEM split flanges?
« Reply #38 on: May 12, 2010, 06:59:51 PM »
they flanges have to come from the dealer  (ebay) ....the heli-coils and bolts you can get at your local hardware store or autozone/advance auto
cb544
« Reply #39 on: May 13, 2010, 04:38:48 AM »
Hmm- excellent!
I'm confused about the flanges though... I've read that the Kerker doesn't need the flanges, but common sense would say there is a gap that needs filling and the stock flanges would do that.
Offline Zaipai
    • My Home page
« Reply #40 on: May 13, 2010, 06:00:49 AM »
Hmm- excellent!
I am pretty sure all SOHC4's require the flanges..  At least the 750 and 550's for sure. I am not 100% sure about the others. I have seen sites that claim you don't need them, however after some one (usually from here) buys them they end up having to get them. I think its miss information..
Some one correct me if I am wrong please..
.: Scott :.
Its my Avatar..
75 CB550F  |
cb544
Enduro?
« Reply #41 on: May 13, 2010, 09:25:31 PM »
I'm suddenly very interested in putting enduro tires such as the Metzeler Sahara on my cb... anyone ever seen this? I've searched all night.. Good night
Re: '74 cb550 ... enduro?
« Reply #42 on: May 14, 2010, 04:56:23 AM »
What type of terrain do plan on riding on?!?
cb544
« Reply #43 on: May 14, 2010, 05:08:50 AM »
Haha- probably mostly city streets, some highway driving to the campsites, fire roads, possibly some true adventure riding if I get her running true enough.
That whole "Be Prepared" thing really stuck in me from Cub Scouts.  ;D
« Reply #44 on: May 14, 2010, 05:09:58 AM »
Sure you can fit Enduro tires on these wheels but a few things to consider about dual sport tires (Ive just got through the same exhaustive search):
1. The Saharas will wear out faster if only street riding - as low as 1500 miles have been reported and high is 5000 miles (for rear).
2. They are noisier than stock on the highway.
3. On the plus side they are apparently good in the rain and decent handling on corners.
Ive been looking at Shinkos (much cheaper and getting a good rep), Dunlop K70s (similar to you have already), Mefo Explorers (may be hard to find the right size though), Tourances (getting expensive here but longer life) and check out TKC-80s - again have a good rep but getting the right size may be an issue. I think I am going to try the Shinkos since they are so cheap - between $40 -$65/tire.
here is something I found comparing all the different tires...
http://faq.f650.com/FAQs/TireOpinionsFAQ.htm
And for off-road riding think about doing the Trans Mass Trail - this is what I am heading for this summer...
good luck
Andy
cb544
« Reply #45 on: May 14, 2010, 05:18:46 AM »
good luck
Andy
Excellent! Thanks Andy- I'll definitely look up that Trans Mass Trail once I get some tires.
I'll keep you all posted on what happens... maybe I can justify the frequent tire changes if I buy Shinkos, or at least plan to be off the road more than on- or build a true enduro further on down the road. :D
Thanks again for the info Andy.
Cheers-
cb544
« Reply #46 on: June 02, 2010, 01:06:50 PM »
New video!
[youtube=425,350]kAlyVPKJx0M[/youtube]
Is that a noisy cam chain? Sure sounds like it... The sound is altered when I get into shift into gear, just  a bit...
There are a few neighbors using lawn tools in the background, but that slapping at idle is distinct.
Would appreciate any insight you have. I loosened the lock nut on the tensioner but the screw/gear wouldn't turn... I imagine it's pretty gummed up in there. I ran about a liter of fuel thru it and it's getting better and better, but the noise won't go, and I don't want to ride it like this. What do you suggest?
Re: '74 cb550 ... Noisy cam chain, eh?
« Reply #47 on: June 02, 2010, 01:22:17 PM »
have you set the tappets ...kinda sounds thats what slappin around ... the tappets in my 550 like to move every 100 miles or so (very annoying)
Offline Zaipai
    • My Home page
« Reply #48 on: June 02, 2010, 05:28:48 PM »
Sounds like she is idleing pretty low also.. It should be at 1000 rpm I believe yours sounds a bit low, tho I could be wrong..
.: Scott :.
Its my Avatar..
75 CB550F  |
cb544
« Reply #49 on: June 02, 2010, 05:30:05 PM »
Very interesting... I have not set the tappets. I will asap and get back you y'all... was kind of perplexed as to why the cam chain wouldn't adjust itself, but maybe it didn't have to. Sounds like a chain slapping tho... of course, it's the first time I've heard a 1974 cb550 run.  ;D
