Author Topic: CB400f Rear Disc  (Read 6083 times)
Offline brandon
Re: CB400f Rear Disc
« Reply #25 on: April 09, 2010, 03:47:22 PM »
Hey Industrial, I'm not here to step on toes. I'm only curious and learn through asking. I think the 6 o' clock caliper looks good too, but my needs are different than yours and that's part of what our bikes different from one-another. If I came across as being pesky, I'll tell you those were not my intentions :)
Now back to converting to rear disc! :D
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #26 on: April 09, 2010, 04:30:43 PM »
you're not stepping on any toes, I'm just messing with you.
I always forget that text doesn't transfer sarcasm.
EDIT: I should put this in when I do that-
« Last Edit: April 09, 2010, 04:34:55 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #27 on: April 09, 2010, 05:24:34 PM »
I just read a few articles on the braking setup of F1 cars vs passenger cars.
the reason they put the calipers on the bottom of F1 cars is heat dissipation (heat goes up) and the center of gravity, because everything on those cars has to have the lowest possible COG.
Offline Stevevo8
« Reply #28 on: April 26, 2010, 11:04:29 AM »
I found a rear hub from a CB750f, could this possibly work?
  • Like a well oiled
    • Undead Asphalt
« Reply #29 on: April 26, 2010, 11:43:24 AM »
try it and let us know.
I think the axle is a different size, so you'll either have to swap swing arms or change the bearings
Offline Stevevo8
« Reply #30 on: April 26, 2010, 11:47:02 AM »
Im looking at it from teh width stand point. Changing bearings might be the easiest part of the whole deal.
  • Like a well oiled
    • Undead Asphalt
« Reply #31 on: April 26, 2010, 01:33:08 PM »
if it's too wide, cut some off. there's always a good amount of spacers in there anyways.
Offline Stevevo8
« Reply #32 on: April 26, 2010, 05:06:39 PM »
Im on it, its gonna be cheaper finding out this way than buying a talon hub.
