Gordon: right, the headers. I'm Dumb. But, The engine stays on for such a short period of time that nothing gets hot (or warm). I just have a second or so at a time.
Update: I dont think that it is a battery problem. I just went out and gave it a try after letting it sit for a couple hours, and I got a burst of engine action (using the kickstarter). Previously I had had no life. It seems to me that if the battery is drained to the point that it can't operate the motor, a few hours rest will not recharge it. Is this true?
And just as a description, in case this means anything to anyone: the engine almost started with the electric starter, and then started completely with the kickstarter. It revved high at first and then backfired and quit. Total duration was less than two seconds. After this, the electric starter would produce nothing. The kickstarter would not catch the engine either, but there was a strange spinning sound (higher pitched, faster, lighter than the engine turning over) that would sound after each time i tried it.
Nikkisix: thanks, I'll try the test. (And Thank You! for the explanation. I need all the information i can get, never am insulted by instruction)
Any Ideas?
Thanks,
Harper
