Author Topic: i need advice on if I should buy these... UPDATE (now with PICTURES :)  (Read 3998 times)
Offline andy8190
Re: i need advice on if I should buy these... UPDATE (now with PICTURES :)
« Reply #25 on: April 09, 2010, 09:46:01 AM »
As you can see they are in rough shape but who knows what they can lead to. I have 3 mufflers 1 of which has absolutely no baffle haha, all the headers dont look bad though. You can see where the one frame was cut off. I have no keys or ignitions for them so any help where to get those would be great. I want to start the cafe one first and use the cut frame. Not sure which motor to use as I am sure both will be cruddy inside.
« Reply #26 on: April 09, 2010, 09:48:54 AM »
Hondakeys
David silver spare/ebay/Z1 enterprises for ignitions.
Offline andy8190
« Reply #27 on: April 09, 2010, 10:44:18 AM »
once I get a new key how do i get the seat latch to match and the steering stem lock to match. Also where can i purchas that brightside boat paint locally ( home depot, lowes)?
« Reply #28 on: April 09, 2010, 11:49:36 AM »
if they have the same serial number stamped on both, the associated key will work.
if not the same, i am unsure if the seat latch can be re-keyed, to your new hondakey, or if a new key can be made from the seat latch tumbler, giving you 2 keys for that bike.
others might be able to answer this one.
Offline starkmojo
  • Yes I am tall...
  • Wow that bike is Orange, but I kinda like it.
« Reply #29 on: April 09, 2010, 02:54:40 PM »
i recently took the seat and ignition lock off a cj360, they had different id numbers, but the same last three numbers the local locksmith cut one key for the both of them.
YMMV
twoold to give up
twotired to care..
wert
« Reply #30 on: April 11, 2010, 11:20:42 AM »
The ignition and seat lock should be the same key, at least it is on my 74.  Find the number on the ignition and contact David silver/ebay/z1.  He can help.  Intrested in head pipes if you care to part with.  I am in Clarksville about 80 miles away from Fayettevile.  Going to the VA in June, maybe get in contact.
