Author Topic: Sprocket, Wheel, Chain Question  (Read 465 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« on: April 07, 2010, 07:56:17 PM »
This is an edited text from the FAQ section. I have been reading ;)
My question: If the below is true, and I have no reason to doubt it, what would my best bet be for me to get back to a stock configuration knowing that I have a 16" on the rear now?
Both his and mine are both CB750 K8s
"In reading many posts online here, I had been thinking of the 630 to 530 conversion, and decided to give it a whirl.  The 15/41 630 setup has a 2.73 ratio.  Closest I could get in a 530 was an 18/48 (2.67 ratio).  I was wanting to gear it down a bit to reduce RPM's on the highway, so that sounded good.  Because the front sprockets were only $22, I ordered a 17t and an 18t, along with the 48t rear."
"Before swapping the sprockets/chain, I wanted to compare RPM's at different speeds.  With the 15/41/630 setup, the bike spun in 5th at 70MPH, 5300RPM.  With the 18/48/530 setup, 70 MPH in 5th is at 5200RPM.  In 2nd, the 15/41 would hit 67 at redline (8500), the 18/48 got up to 70MPH at 8500RPM."
Anyone care to take a shot at my 16" rear wheel change on this.
nut ulat of areithmatic buuk lurnin in mi husoe ;D
Offline Gordon
  • 750K1, 550K2
Re: Sprocket, Wheel, Chain Question
« Reply #1 on: April 07, 2010, 08:07:49 PM »
What size tire do you have on that 16" rim?  If it's a relatively tall tire the fact that you have a smaller rim may not make that much difference.
« Reply #2 on: April 07, 2010, 08:13:57 PM »
Measure the height of the tire, its probably within  1/2 in of the Stock 18 in tire sizes..
 .. nothin to worry about, unless you rather it did something else.
