Author Topic: Auto Meter Gauges?  (Read 1211 times)
Offline Zev Fisher
Auto Meter Gauges?
« on: April 07, 2010, 10:33:43 PM »
Hey All,
I was thinking about potentially replacing my stock cb750 gauges with these really slick Auto Meter gauges. Does anyone know if these are a 4:1 tach ratio, and if the mechanial speedometer cable can be modded to work with this speedo?
http://www.summitracing.com/parts/ATM-4493/
http://www.summitracing.com/parts/ATM-4497/
I have a dyna S ignition of that helps...?
Has anyone ever tried this before?
Thanks!
-Zev
Offline Ernie
  • Dead again,could I get a
Re: Auto Meter Gauges?
« Reply #1 on: April 08, 2010, 07:08:35 AM »
hi zev,I'm no expert but I dont think the speedo would work because of the size difference @ the cable connection ,also you need to get the correct ratio's for your bike.    http://forums.sohc4.net/index.php?topic=265.msg435880#msg435880   hope I helped a little :)
Its all happening !
my 1978 CB550K.......>>>
http://gallery.sohc4.net/main.php?g2_itemId=4440
Offline Steve F
« Reply #2 on: April 08, 2010, 10:15:10 AM »
Looks great...don't get 'em wet.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #3 on: April 08, 2010, 10:35:32 AM »
Hey All,
Thanks!
-Zev
I know they don't make a mechanical tach but hooking one into the Dyna ignition shouldn't be an issue. They do make a 2240:60 mechanical speedo but again mating the cable with the gauge is the issue. You might be able to get a helicoil adaptor to fit on one of the ends of the speedo cable.
I also notice on their site they have a line of motorcycle gauges that may actually, by design, be more weather and vibration resistant.
But, overall, they are quite expensive.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline Doctor_D
« Reply #4 on: April 08, 2010, 08:32:29 PM »
As far as weathertight gauges go, the ones you want are the ProCycle gauges.
I'm not sure the tach can handle a four cylinder motor, but I haven't looked either. Also not sure if they have a model where the revs go high enough for a Honda.  They only go to 8k on mine, which is plenty for a long-stroke pushrod twin.
Take care,
David
1978 CX500
1971 Norton Commando
