I recently took my carbs off, reset all of the float heights, and bench synched them with the light method. I did this because I was having some smoking, popping, and a few flat spots on my throttle. After I reinstalled the carbs I took the bike for a test ride around the block. I could quickly tell it wasnt running very well. When I got back home #1 was cold. I pulled the float bowl and there was no gas in it, all the others had gas. I took off the float and reset the tang and it flowed. I'm not for sure if it was a stuck float pin or the float was to low.
Anyways, now all of my sparkplugs look pretty good except for #1 which is wet with gas. I'm not leaking any gas out of the overflow tube. So what would cause this condition? I know it means that the cylinder is running too rich but I tried messing with the air mixture screw and that doesnt help at all. Would the next thing be to adjust the slide height?
Thanks!
