Author Topic: Float bowl gaskets  (Read 926 times)
Offline cadler
Float bowl gaskets
« on: January 23, 2006, 08:00:21 AM »
The rebirth of my 71 cb750 is going great with some small bugs.
One problem I am having is that my float bowl gaskets(brand new)
Seem to be fatter than origanal and are hanging up my floats either up or down. I am on my 2nd set of gaskets and only one carb is currently getting hung up.
Anybody run into this?
thanks
Offline Bob Wessner
  • "Carbs Suck!"
Re: Float bowl gaskets
« Reply #1 on: January 23, 2006, 08:41:07 AM »
Have to admit, I'm having trouble picturing this. What was the source of your new gaskets?
Offline dusterdude
« Reply #2 on: January 23, 2006, 09:56:57 AM »
cadler,if your`re using honda gaskets i had the same problem.now the fix,i bought some gasket material from napa and cut my on or perhaps you could trim the gasket you have now and see if it works that way.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cadler
« Reply #3 on: January 23, 2006, 10:44:29 AM »
I bought the gaskets from E bay. They were from honda carb rebuind kits and the gaskets were not needed.
Offline cadler
« Reply #4 on: January 23, 2006, 10:47:06 AM »
DusterDude:
I trimmed 2 with a razor blade, one so far seems to work ok. the 2nd one did not.
I may have to try cutting my own.
Offline 6adan
« Reply #5 on: January 23, 2006, 03:34:30 PM »
Your float may have gotten bent out a little.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline dusterdude
« Reply #6 on: January 23, 2006, 05:24:23 PM »
i forgot to add,my honda gaskets swelled like a pregnant ladies stomach when gas hit em too
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
