Author Topic: 1977 cb750f2 (915cc)  (Read 240601 times)
0 Members and 7 Guests are viewing this topic.
Re: 1977 cb750f2 (915cc) Trying a new pipe
« Reply #925 on: January 14, 2014, 11:06:25 PM »
The cone looks good Tige, is it a 12 inch..?
thanks fellas.  I don't think it looks as good as the Motogp pope but I can't have a pipe that hits my oil filter.  Yes Retro, it's the 12 inch.
You can leave the pope out of it mate, i only wanted to know the length of the muffler..... ;D  ;)
Offline mrbreeze
  • Not your average
« Reply #926 on: January 14, 2014, 11:48:35 PM »
 ;D ;D
MEMBER # 257
Offline tweakin
  • tear down
« Reply #927 on: January 15, 2014, 04:39:22 AM »
Guess thats what I get for trying to respond via cell phone. ::)
« Reply #928 on: January 15, 2014, 10:16:42 AM »
Looks good Tige.
Ceramic on these is the way to go to maintain that SS color, or black it out.
SS yellowing is the only thing I dislike.
Offline tweakin
  • tear down
« Reply #929 on: January 15, 2014, 11:47:20 AM »
Looks good Tige.
Thanks Rob.  I actually love the look of stainless once it starts to turn gold, one of the reason I dig stainless pipes.  I am looking forward to the heat discoloration.
Offline snowman
« Reply #930 on: January 15, 2014, 05:26:44 PM »
With the "Turd" (71 cb750 build) in full swing, I decide to try a new pipe arrangement on the 915.  The motoGP stainless pipe is awesome but still hit my remote filter housing since I am running an oil cooler plate, it fits fine on a stock set up.  Plan is for the motoGP pipe to go on the turd so I decided to do something different with the Kerker to get the look I want.
Had the Kerker header ceramic coated and added a Cone Engineering 2.5 inch stainless can on it, just the look I am going for.  Not sure how the performance differences will stack up but I am more than happy.  Just wish I had easier access to a dyno so I could have tested all the different pipe set ups.
Also picked up some new all black Joker Machine clutch and points covers, I like the simplified look of no fins.
I have to say that the best look there is, but then again I'm kinda bias. Have a look at the exhaust I mocked up for my build.
Probably the same can, the only thing is that my 4-1 is a bit to bad to get it coated, so,I'll use wrap until I can find another set of pipes.
Sent from my iPad using Tapatalk
Offline snowman
« Reply #931 on: January 15, 2014, 05:30:53 PM »
By the way, had a closer look and was wondering what type of bolts are those you used to replace the exhaust studs. they're not normal Allen bolts, are they?
Offline tweakin
  • tear down
« Reply #932 on: January 15, 2014, 06:36:06 PM »
Love your exhaust choice snowman!  I removed the exhaust studs and am using 8mm stainless button head bolts, nothing too special.  Picked them up from bolt depot.com.   I saw in another thread you were looking for a place to buy replacement hardware, checked bolt depot for you but doesn't look like they ship outside the states.
« Reply #933 on: January 15, 2014, 06:43:09 PM »
Hey Snowman - Canadian Fasteners should have what you need, is this near you?
http://www.ancragescanadiens.com/produits_en/produits.html
Offline snowman
« Reply #934 on: January 15, 2014, 06:52:12 PM »
Close enough and I'll  try to go by on the weekend or next week. Thanks Steve-o
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #935 on: January 15, 2014, 08:31:21 PM »
I don't think it looks as good as the Motogp pipe but I can't have a pipe that hits my oil filter.
I disagree Tige. I've always thought the Yoshimura knock off pipes look incomplete.
The SS megaphone looks the biz. Think I'll follow your lead if you don't mind.
Offline tweakin
  • tear down
« Reply #936 on: January 16, 2014, 06:52:39 AM »
I do understand what your saying Jim.  I think a similar set up would look great on the Intercepter!
« Last Edit: January 16, 2014, 06:55:03 AM by tweakin »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #937 on: January 16, 2014, 09:48:33 AM »
I do understand what your saying Jim.  I think a similar set up would look great on the Interceptor!
Ordered!
Offline snowman
« Reply #938 on: January 16, 2014, 04:52:07 PM »
Forgot ask earlier, what length did you use for the button head bolts. I know for studs they're 52mm and I'm sure they don't need to be that long.
Offline tweakin
  • tear down
« Reply #939 on: January 16, 2014, 05:28:08 PM »
Cant really remember.  I believe I bought 55mm and cut them down a bit.  The Kerkers flanges are pretty deep, so really depends on the header you have.
Offline Stoli
« Reply #940 on: February 15, 2014, 12:40:45 PM »
Quick question for you. I am trying to figure out which pods to go with on my second project and noticed that you have the K&Ns on this bike. I went with the APEs on my first bike to save a few bucks and they seem fine to me but the K&Ns get a lot of hype and I am trying to figure out if it is the design, construction or both.  I've gone through all the pod threads on this forum and the one thing that has been mentioned a few times is that the K&Ns have a built in "velocity stack". I have yet to find a decent picture of the inside of a K&N to do a comparison with the APE. I'm not asking you to go through the hassle of a pic, but was wondering if you could tell me the depth of the K&N that would be the equivalent of the APE dimension shown in the pic below? Essentially the APE has a 1" non-tapered tube for a "velocity stack". What does the K&N have?
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
« Reply #941 on: February 15, 2014, 06:10:12 PM »
The K&N's have a taper at the mouth of the rubber area. It is kinda crude but you can see where a sanding roll has hit it to smooth it out. The taper is predominant on the upper and lower part of the rubber intake.
Offline tweakin
  • tear down
« Reply #942 on: February 15, 2014, 09:19:12 PM »
Thanks Mike!
Offline Godffery
  • Godffery's Garage
« Reply #943 on: February 15, 2014, 09:50:09 PM »
The K&N's also have a MUCH better filter material and are not as prone to experiencing a lean condition in a cross wind, which is the primary reason I ONLY use K&N.
I also like to use the K&N Air Filter Wraps, shown here in this pic: http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Waterhouse+Performance+motor+build/WH-147.JPG.html?g2_imageViewsIndex=1
http://www.knfilters.com/search/wrap.aspx
Offline Stoli
« Reply #944 on: February 16, 2014, 04:06:25 AM »
Thanks guys. Can anyone tell me how deep the rubber intake area is?
My Project Threads:
Offline InAquaVeritas
« Reply #945 on: February 16, 2014, 05:46:36 AM »
I'm running pods as well, the PO installed them and rejetted the carbs, but it still runs a bit lean. They should be K&Ns as well, I'll check.
I don't have a huge problem crosswinds, but I do with rain. I live in a very wet climate (the Netherlands) and they get saturated with water when parked for a bit or ridden in rain and spray. It doesn't get enough air in and it floods itself, even at 5000 rpm doing 100 km/h.
I will be taking them off Monday the 24th as I will start work on my bike, I can take photos if you still need more info.
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline Stoli
« Reply #946 on: February 16, 2014, 11:11:43 AM »
A pic would be great, and a measurement as well.
Sorry for hijacking your build thread Tweakin. Last thing I wanted to do was start another pod discussion.
My Project Threads:
« Reply #947 on: February 16, 2014, 11:13:11 AM »
No problem, I'll send you a PM with all this, unless someone else is looking for this info
Past "bikes" ;)
Offline Calumjs
« Reply #948 on: February 25, 2014, 03:46:04 PM »
Hey did you instal some sort of spring return on the rear brake rear set?
Offline tweakin
  • tear down
« Reply #949 on: February 25, 2014, 05:43:10 PM »
Yes, If you look closely at the pics above you will see the spring behind the Brembo Master cylinder push rod, I wrapped it in heat shrink tubing.  It doesn't snap the foot brake back up after using, but puts pressure on it so it has good return and does not allow the foot brake to remain without tension.
