Author Topic: K1 project need some info....can't find it in search  (Read 1411 times)
Offline 750four
  • Bomb's away!!!
« on: April 10, 2010, 03:20:02 PM »
Title: 1970 Vin 1003***
Engine: CB750E-1063553 (K1?)
Cam: R5 and also stamped H and I
Head: stamped C22 and Z on the bottom and E I and 4 11 or 4 77.- What gen or year is this head?
I aslo think the cam is DONE...the lobes are starting to look a little bit like shark fins...
Any help would be awesome.
« Last Edit: April 10, 2010, 03:28:18 PM by 750four »
Offline greasy j
  • lanesplitting
  • non serviam
Re: K1 project need some info....can't find it in search
« Reply #1 on: April 10, 2010, 03:41:44 PM »
this might help
http://www.sohc4.net/index.php?q=content/cb750
I have a K1, mine is 1072538
Offline 750four
  • Bomb's away!!!
« Reply #2 on: April 10, 2010, 04:19:04 PM »
Thanks for the link, but I really am just wondering what the head came from. I imagine since it fits the motor it must be a good mate for it. I know that they are different from 76 on.
Are the cams supposed to look like that? Where can I find the cam bearings/journals ( tops and bottoms)?
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #3 on: April 10, 2010, 04:35:09 PM »
a lot of my engine parts including my cam are at school. I go back on tuesday, I can check then if you haven't found out yet. as far as cam bearings/journals I'm not sure. do you mean the holders that bolt on top? I get confused with terminology sometimes and make up my own names for things...
I know my head has that 77 or 11 looking mark on it. I thought maybe it was japanese markings?
someone here can help you for sure. if not, I'll check in after school on tues.
if you click the link in my sig, at the bottom. 'project ultra' there are some good pics of it all coming apart, and you might be able to reference your head with mine. I know mine is original if that helps.
