Author Topic: I think I really fudged this one. Suggestions?? GL1000 front end swap  (Read 942 times)
Offline olc101
  • CR750 Junkie!!!!
I received my tapered bearings in and started to do the install with the great thread on here. I punched out the old races put in the new ones. Froze the the lower tree and stem, and read about removing the old tapered washer at the bottom of the stem  before install.I went ahead and compared the one on my original 750 and the one on the GL front end. The GL looks like it has considerably less of a taper so I figured I wouldn't use the spacer and run it with the original tapered on. I pounded down the tapered bearing into the frozen stem and tree and still don't have enough stem length due to the original tapered washer. Any one have any suggestions on how to remove the tapered bearing off the stem with out ruining it so that I can start over???   :'(
1973 CB750
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
Re: I think I really fudged this one. Suggestions?? GL1000 front end swap
« Reply #1 on: April 11, 2010, 01:32:48 PM »
Were you saying something? I couldnt stop looking at your avitar.
Maybe heat? But that might not be good for the bearing?
Jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
« Reply #2 on: April 11, 2010, 02:23:49 PM »
Since you have something under the bearing, it should be easy to tap off the bearing.. just make sure you are striking the steel inner, not the cage or rollers..
 Myself I would not bother with the freezer..
Offline ev0lve
« Reply #3 on: April 11, 2010, 02:33:25 PM »
Just out of curiosity are these All Ball's tapered bearings or a different manufacturer?
Offline olc101
  • CR750 Junkie!!!!
« Reply #4 on: April 12, 2010, 08:39:34 AM »
I can't stop looking at it myself. :o
I kept trying to remove the bearing and couldn't make it budge so I ended up ruining the bearing, sucks but oohh well.
Now I'm working on the tapered washer on the stem. This is even harder to remove than the bearings. I tried it on my 750 stem and it popped out by simply prying it up with a flat head. This is simply not the case with the GL washer, I have been relegated back to the hammer and flat head..
I bought the bearings from parts and more. I have to buy another set as I believe these only come in pairs.
1973 CB750
Offline MaaseyRacer
    • Fuelist
« Reply #5 on: April 12, 2010, 09:06:41 AM »
This happened to me, I just used a rag and a bench vice.  Then tapped the stem with a hammer.  Bearings are tougher than you think.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline domer
« Reply #6 on: April 12, 2010, 09:34:59 AM »
pm sent... might have a bearing for ya!
Offline olc101
  • CR750 Junkie!!!!
« Reply #7 on: April 12, 2010, 10:47:38 AM »
Pmed you Domer.
1973 CB750
