Author Topic: help, no power  (Read 891 times)
imsam817
help, no power
« on: April 12, 2010, 12:39:41 pm »
so i have a 77 honda cb550f.  it was running great for a couple weeks then at a stop light the lights went out then the engine died on me.  i haven't been able to get it started since.  i replaced the regulator and rectifier, put in a new ignition switch, checked/replaced the fuses, don't know what else to check.  took the coils in to a shop to have them checked, the coils are good.  oh and the engine/starter turns over, just there isn't a spark so it doesn't start up...  btw i live in the SF bay area, so if anyone knows of a good mechanic i'd appreciate it.  thanks
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: help, no power
« Reply #1 on: April 12, 2010, 12:42:42 pm »
you didn't check the points yet?  Also check the kill switch.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
imsam817
Re: help, no power
« Reply #2 on: April 16, 2010, 08:37:43 am »
the points were replaced with a dyna s, so the points aren't a problem.  as for the kill switch, do you mean check the switch mechanism itself?
Offline razor02097
Re: help, no power
« Reply #3 on: April 16, 2010, 10:16:45 am »
I mean see if the coils are being grounded if the switch is also connecting.
Project Rina
Offline domer
Re: help, no power
« Reply #4 on: April 16, 2010, 10:22:34 am »
where at in the bay?
Offline Spanner 1
Re: help, no power
« Reply #5 on: April 16, 2010, 10:28:04 am »
Take another look at your fuse block. Are the fuse clips nice and shiny? are the clips getting a firm grip on each fuse ? Look at the backside of the fuse block too..... any cruddy connections  at the fuse will show-up due to the extra load of the Dyna ignition you have on your bike....and BTW, YOU are the best mechanic for troubleshooting your bike !!
