Author Topic: Machining .007" from carb slides  (Read 1907 times)
Offline garretcb750
« on: April 12, 2010, 06:13:08 PM »
Cycle exchange states benefits from machining .007" from the bottom of the carb slides, has anyone tryed this?
Offline Doctor_D
Re: Machining .007" from carb slides
« Reply #1 on: April 12, 2010, 07:32:39 PM »
It has the effect of reducing the slide cutaway and enriching the off-idle transition. The circuit it effects is between the idle circuit and the needle taper/position.  It should be most pronounced at about 1/8th throttle. (Just like going from a 3 1/2 to a 3 slide on an Amal.)
If you have a free flowing exhaust and intake and you have an off-idle hesitation or flat-spot, then the mod should help improve throttle response.
Take care,
David
1978 CX500
1971 Norton Commando
Offline garretcb750
« Reply #2 on: April 12, 2010, 07:45:10 PM »
Has anyone done this with good results?
Offline fastbroshi
  • Puppet
« Reply #3 on: April 12, 2010, 08:20:10 PM »
  I thought Honda at one time sold replacement throttle valves with different angles to them?
Just call me Timmaaaaay!!!
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: April 12, 2010, 09:12:50 PM »
I think I need to do that, I can't seem to get that flat spot out during a quick throttle twist.
http://www.cyclexchange.net/Carb%20Tech%20Tips%20Page.htm
« Reply #5 on: April 12, 2010, 09:21:41 PM »
 Acellerator pumps should cure that... ;)
  • Like a well oiled
    • Undead Asphalt
« Reply #6 on: April 12, 2010, 09:44:21 PM »
that's the easy way out.... quitter.
;D
