Author Topic: CB750K1 carb problem - SOLVED -  (Read 6213 times)
Re: CB750K1 carb problem - SOLVED -
« Reply #25 on: April 15, 2010, 03:44:28 pm »
Glad you solved a mystery.  But here is another.
Why does your bike have a problem with the overflow/vent tubes but millions of others don't?
« Reply #26 on: April 15, 2010, 03:57:52 pm »
Well done Johnie! Very informative thread!
Andy
Offline Spanner 1
« Reply #27 on: April 15, 2010, 06:06:04 pm »
Wow, some kind of harmonic @ 50 mph airflow!!..... like blowing across a soda straw.... I wonder what 'tune 'those 4 hoses were playing in the wind ?.... I hope it wasn't any Neil Diamond number !!
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #28 on: April 15, 2010, 08:55:33 pm »
Where the heck are these things suppose to go? There is no bracket on my K0 or place to nest them....
Congrats Johnie!
« Last Edit: April 15, 2010, 08:57:52 pm by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline shorterdanny
« Reply #29 on: April 15, 2010, 10:50:42 pm »
congrats buddy,
hopefully mione is something just as easy to solve, was relieved to see the thread title changed to solved.... ;D ;D
have ordered new floats and going to try different positions today..
as to why this doesn't affect every bike, prob down to a fluke combo of the variables, position, length, jet size, float effiency, but just as long as its fix..
well done people..............
1983 Honda CBX 750
1978 CB750 K7
Offline Magpie
« Reply #30 on: April 16, 2010, 06:41:45 am »
So the problem WAS in the overflow tubes - knew it!  ;D ::)
Good on you for finding it Johnie! Another thing to be aware of.
Cliff.
Online Johnie
« Reply #31 on: April 16, 2010, 08:22:24 am »
Cliff.
The only difference I can see from the OEM and the tubes I put on which are the same size, is I cut the lower end on an angle on all 4 tubes. Does the angle have something to do with allowing more air to affect the pressure in the bowls I do not know. Today I plan to cut those tubes straight at the bottom to remove that angle cut and test it out with the tubes hanging straight down. I will report back...below is a pic of the tubes in the position which caused the problem. They run between the swing arm and case. Then they exit in front of the center stand post.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #32 on: April 16, 2010, 08:23:55 am »
yippeeeeeeeeeeeeee ;D
tried repositioning the carb overflow pipes to behind the swing arm. and all good problem solved..
no hesitation upto 80mph and still pulling strong just ran out of road.
Really don;t think i would have ever thought of a 2 sec move of the pipes without this thread. So thumbs up all round
Thanks to all in this thread. just what the forum thing is all about..
1983 Honda CBX 750
1978 CB750 K7
Online Johnie
« Reply #33 on: April 16, 2010, 08:30:18 am »
Man that is great Danny!!! Glad it worked for you too. Now here is something to think about. I noticed that on the OEM tubes I removed and the new tubes I installed the effects of the fuel & vapors on the end of the tubes have swelled them open a bit more than when they were new. I wonder if the swelling which makes that end hole larger could have something to do with it?
Oshkosh, WI  USA
« Reply #34 on: April 16, 2010, 08:45:37 am »
my tubes are just some random clear tubes that the PO had put on, but yes they to have swelled a little.
remembering back to school physics. the pressure and velocity and temp will all vary as the diameter of the pipe changes, so i pressure that there is an occasion why these varibles and the airflow over the end of the tube could cause weird stuff to happen along the pipes length (and into the bowl).
what can i say never going to be a professor  ??? but just glad it work, will certainly have me looking at other seemingly insignificate areas in the future.
1983 Honda CBX 750
1978 CB750 K7
Offline tlbranth
« Reply #35 on: April 16, 2010, 10:18:45 am »
So Johnnie, where are you getting brass floats for $17? I just ordered one and it's costing over $40 with tax.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Online Johnie
« Reply #36 on: April 16, 2010, 10:36:04 am »
The $17 brass floats was the Yamiya price. I put on some plastic ones I had from a set of K4 carbs with 4,700 miles. To be honest, I am going to replace all my brass floats. That is the 3rd one I had with pin holes.
http://www.yamiya750e.com/index.php?main_page=product_info&cPath=27&products_id=147
« Last Edit: April 16, 2010, 10:37:54 am by Johnie »
Oshkosh, WI  USA
