Hi everybody,
I'm trying to tune rebuilt carburetors, but don't have a vacuum gauge, so it's going slowly. I have a 1975 CB 750K, all stock except for a 4 into 1 exhaust. My current issue is that the engine lugs from about 1/4 to 1/2 throttle (I don't know if there is an official term for my engine's misbehavior. When I get to this throttle position it loses power, drops in rpm and tone, and feels like it would die if I don't release the throttle back under 1/4 or give it over 1/2). Additionally, if I snap the throttle open from idle, the engine misses and dies. The bike performs better (the area of stumbling is smaller) if I slowly apply throttle, and after completely warming up. Finally, unless completely cold, the bike needs almost no choke to start, and in fact, will sometimes die if I try to start it with the choke.
I read the carb FAQ and tried some of the diagnostics. I tried removing and covering the airbox and comparing performance to see if it was running rich or lean, and the engine seemed to perform better with restricted airflow. Because the problem area was in the middle of the throttle range I raised the needles one notch. This has not solved the problem; performance seems unchanged. I've done further testing, but there is no noticeable difference between rich and lean set ups.
I used very thin wire to bench synch the carburetors when I was reassembling them. Could my problem be that the slides are too low? I read that having too little cutaway open on the airbox side can cause too much vacuum, and result in the kind of "snapped-open-throttle death" that I'm experiencing. This might also explain the rich starting mixture (why I don't need the choke)?
Thanks,
Harper
