Author Topic: It's a chopper, baby. My CB750K0 rebuild (warning LOTS of pics)  (Read 49170 times)
Offline mystic_1
  • 1970 CB750K
Re: It's a chopper, baby. My CB750K0 rebuild
« Reply #75 on: March 06, 2016, 01:03:02 PM »
Just to expound a but more about the blasphemy I had just conducted upon my frame, the point where the main backbone tube meets the cross brace at the front of the seat, is all just made of sheet metal.  There are two pieces that form this joint, an upper and a lower plate, which are shaped around the auxiliary backbone rails and the main backbone end, then welded in place.  This is what was bending when I was doing the above, you'll probably be able to see the deflection in these pieces in later pics.
And this is the main problem with cutting out the auxiliary backbone rails - they're not really "auxiliary."
They are, in fact, far far stronger than the way the main backbone tube is "secured" at its end!!!
When you remove these, the only thing holding the backbone together is the sheet metal shape described above.  Most of the bottom plate isn't even there, there's large ventilation openings down there to keep water from accumulating inside the gusset.
Go on out to your bike and knock on these pieces with your knuckles, and then tell me if that's the only thing you'd like to have holding your steering head in place.
Me neither.
mystic_1
- John Augustus Shedd
Offline mystic_1
  • 1970 CB750K
« Reply #76 on: March 06, 2016, 01:42:42 PM »
But first, I needed a way to put it all back together again.
You can't just butt-weld the tubes back together, that's not strong enough.  Nor do you want to use solid slugs, as they won't flex as much as the surrounding tubing and hence will tend to concentrate stresses at the upper and lower ends of the tubing, right at the steering head and the motor mounts.
So, I acquired a supply of 1020 DOM round steel tubing in 0.065 wall thickness, the same as the factory frame tubing.
I got several feet each of 7/8", 1", 1 1/8", and 1 1/4" tubing.
I'm cutting these on my poor-mans-chop-saw which is a 4 1/2" angle grinder mounted to a stand I bought on Amazon for $20.
The 1 1/4 tubing will be used to extend the main down tubes.  The 1 1/8" tubing will be used to make slugs for these joints.
The 1" tubing will be for fixing the auxiliary backbone tubes.  I wanted to come up with something nice looking for this, even though it would barely be visible, because it would please me to do so.
The 7/8" tubing will be used to make slugs for the aux tubes.
Now, the problem here is that the slug tubing doesn't quite fit into the main tubing, so I'll have to reduce the outside diameter.  No problem, just walk over to the lathe...
... but I have no lathe :(
What I do have is a long bolt and some cone washers...
... and a drill press ...
... and an angle grinder.
What I did was, spin the tubing at the lowest speed in the drill press and then use the angle grinder with a coarse flap wheel, moving up and down the length of the tubing as it spun.  In this way I was able to more-or-less evenly remove material a little at a time, until I achieved the diameter I needed.
Barbaric, I know  ;D  but it worked! I was able to reduce the outside diameter enough to get a tight slip fit on the main tubing.
On the main tubing I had to first remove the barb left by the cutting wheel of the tubing cutter.  Tubing cutters are actually "pushing" their way through the material, rather than "cutting", and instead of material being removed by the teeth of a saw, it's being deflected to the sides by the tapered carbide wheel.  So  the ends of the tubing end up getting thicker, leaving a ridge on the inside and the outside that needs to be removed.  Also used a dremel to lightly dress down the weld on the inside of the tubing, just enough to slip the slugs inside.
To join them, I'll bevel the ends to create a weld channel, and drill cross-holes in the outer tubing in order to put in some plug welds.  The idea here is that the plug welds provide much of the strength of the joint.
I don't recall what size hole I ended up settling on for the plug welds, but it was sized such that once I'd welded all the way around the circumference of the hole once, the center of the hole was filled to slightly above the surface.  The pieces you see here are test pieces.  I did a bunch of practice welds to perfect my technique and tune my machine settings before doing the frame for real.  Also cut up a bunch of these afterwards to check penetration etc.  Ended up dialing up the heat just a bit from what you see here.
mystic_1
« Last Edit: March 06, 2016, 01:53:59 PM by mystic_1 »
Offline mystic_1
  • 1970 CB750K
« Reply #77 on: March 06, 2016, 01:51:32 PM »
These two photos from before and after show off how much the front wheel moved.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #78 on: March 06, 2016, 02:12:38 PM »
Now, the next issue is, the replacement piece can't be straight, it must be bent in the middle to meet the ends of the frame tubes nicely!  This may not be obvious in the photos but you'll see as we move along.
Harbor Freight to the rescue!
Now, a pipe bender is NOT a tubing bender.  I'm only after some very mild angles, otherwise I wouldn't have been able to get away with this.
Also pipe bending dies are not the same size inside as tube bending dies, so I used some extra brass stock I had laying around to take up the space between the tubing and the die, so that the side walls would be properly supported and avoid kinking or flattening the tube more than necessary.
Cranked out two identical bends, then trimmed them to length.
Cross-drilled them and made up slugs.
Prepped the frame ends.
Test fitted. Looking good so far!
You can see that there are still some small alignment issues, due to the fact that the downtubes actually taper outwards slightly as viewed from the front.  Also, because the arc of the bend when I jacked the frame open, the front-to-back alignment is a bit off as well.  I'll address those in the next post.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #79 on: March 06, 2016, 02:25:39 PM »
So, the upper frame tube ends needed to come back to the rear a bit.  Super Ratchet Strap Power, GO!
The upper ends also needed to come in a bit.  MOAR STRAPS!
Also used a bar clamp in spreader mode to push the new tubing where I wanted, then eased off on the jack to lower everything into place.
I had to adjust the straps and clamps slightly as I jiggered things around and got it all lined up.  Also had to make sure the inner slugs ended up in the right places, by looking through the holes and helping things along with a pick sometimes.
Removed the ratchet straps.
Lowered the stand lift until the tires just touched.
Put a ratchet strap around it all to keep the gaps closed up tight, and put the bike on the ground.
More to come.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #80 on: March 06, 2016, 02:29:50 PM »
Up one more time for welding.
Off the stand on it's own legs for the first time in a few years.  (You're seeing all of this in time-lapse).
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #81 on: March 06, 2016, 02:40:51 PM »
So cracked open a Guinness and then threw some more tubing into the bender, and came up with this...
Taped into place with masking tape.  Me likey.
Made two.
Prepped ends and made slugs.
Plug welded.
And then it looked like this!
Just have to go back and do finish welding and dress everything down.
But first, I just had do do some more mockups.  The seat you see here is really just the cover and the foam sitting on the frame and fender.
mystic_1
« Last Edit: March 06, 2016, 03:03:48 PM by mystic_1 »
« Reply #82 on: March 06, 2016, 03:11:21 PM »
OMG!
Offline mystic_1
  • 1970 CB750K
« Reply #83 on: March 06, 2016, 04:30:59 PM »
How To Make The Wrong Seat Fit Your Motorcycle, in 124 Simple Steps!
See, easy!
mystic_1
Offline Desert-SOHC
  • It's old
Re: It's a chopper, baby. My CB750K0 rebuild (warning LOTS of pics)
« Reply #84 on: March 06, 2016, 05:48:43 PM »
Nice work and detail!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #85 on: March 06, 2016, 06:13:12 PM »
Nice job adapting the seat pan.
Offline Buckskin Bandit
  • The (unofficial) Official Bolt Head Rounder
  • A "Chopper" project
« Reply #86 on: March 06, 2016, 06:33:59 PM »
Wow... Wow.. That's great work!  8)  I'd like to go that route on mine, if I ever get it running  >:(  :P
Keep the shiny side up and the greasy side down!
1973 Honda 500 four "Chopper" - In pieces :P
1977 CB750 K1 "The Fonz" project
2003 Suzuki GZ 250 "Little Horse" -Sold
1981 Yamaha Maxim 550 "Big Red" -Sold
2007 Shadow Spirit 750 "Blaze"
My resto threads: http://forums.sohc4.net/index.php/topic,152344.0.html
http://forums.sohc4.net/index.php/topic,166240.0.html
Offline mystic_1
  • 1970 CB750K
« Reply #87 on: March 06, 2016, 07:51:52 PM »
Thanks guys, it took a long time to get this far but I was very pleased by this time at how things were turning out.  After several years as a pile of parts, the bike was starting to shape up again!  This was a big boost to my gumption to forge ahead, especially since the motor had been finished by this point and was just waiting in the basement for me to finish up the rest.
The mods to the frame worked out just how I had wanted, and gave me enough room that I could now tear down the motor in the frame if needed.
The seat was a big deal too, as I do a fair amount of two-up riding and I wanted my passengers to be comfortable.  There was still some work to do in this regard, as the stock passenger footpeg mounts are sort of low, I knew I'd need to address that and had plans for something while I worked out the exhaust, which was the next major step.
I have to sort through some more pics before I'm ready to post more, thanks for the comments so far.
cheers
mystic_1
« Reply #88 on: March 06, 2016, 08:00:58 PM »
FYI - you've been nominated and seconded for BOTM.  Please go to the BOTM nomination thread and post an acceptance before the 15th.
http://forums.sohc4.net/index.php/topic,155586.0.html
Offline mystic_1
  • 1970 CB750K
« Reply #89 on: March 06, 2016, 08:14:18 PM »
Wow thanks for the heads-up, i accepted.
mystic_1
« Last Edit: March 06, 2016, 08:36:49 PM by mystic_1 »
Offline mystic_1
  • 1970 CB750K
« Reply #90 on: March 07, 2016, 08:08:42 PM »
So just a few words about hardware.
I'd grown weary over the years of dealing with the old corroded hardware, so during this rebuild I basically replaced every fastener on the bike with a combination of chrome or stainless allen bolts and acorn nuts.
The larger acorn nuts such as for the upper shock mounts, triple tree pinch clamps, and so forth were off-the-shelf chrome steel items from Ace hardware...
... but for some of the smaller nuts I was only able to find some fairly plain looking ones in stainless.
So I took an old 6mm screw, and cut off the head.
Screwed the acorn nut onto the shaft.
Chucked it up to the drill press.
Spun it and used files to basically sculpt it to the shape I wanted.
Initial polish on the drill press with scotch brite.
Final polish on the buffer
Various stages of completion and polishing
Most of the allen hardware I used was also stainless.  When I ended up with bolts that had markings on the heads I removed them and polished.
Other critical hardware was replaced with brand new OEM parts, such has the seat hinge pin hardware.
The swingarm pivot bolt's nut and washer
Caliper mount bolts
Steering stem cap nut and washer
I also managed to source some chrome engine mount plates.
I even managed to get a hold of newly-replated engine mount bolts from a fellow member here.  (sorry no good pics of those).
I was determined that by the time I was done, there would be zero corrosion on the bike, down to the smallest fastener.
mystic_1
« Last Edit: March 07, 2016, 08:45:49 PM by mystic_1 »
Offline mystic_1
  • 1970 CB750K
« Reply #91 on: March 08, 2016, 05:17:23 AM »
I scored these 4-2 crossover pipes and briefly considered running them, but in the end I decided that:
A. I wanted 4 mufflers
2. I didn't like the way these flowed with the lines of the bike.  Too "angular" and abrupt in the side profile.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #92 on: March 08, 2016, 06:59:51 PM »
Exhaust design goals:
- Four long tapered megaphone mufflers (iconic)
- Mounted higher than stock exhaust (to accommodate lowering of bike)
- mounted as close as possible to bike
- good cornering clearance
- minimally visible mounting hardware
- repackable mufflers
- Cut off and use forward portion of stock exhaust shown upthread (from an early 80s' Honda Nighthawk, I believe.  Salvage yard parts from years ago).
While I was mulling it all over, I started mocking up the front end, instruments, and lights.
mystic_1
Offline Desert-SOHC
  • It's old
« Reply #93 on: March 08, 2016, 07:03:23 PM »
Wish I could find a set of Invader wheels that I can afford!  :-[
11 Ranger S/C 2wd
Offline mystic_1
  • 1970 CB750K
« Reply #94 on: March 08, 2016, 07:10:05 PM »
Spotted a NOS pair of these mufflers at a swap meet and got them for a good price.  Ended up buying two more online, as the only other ones I could find at swap meets were rough.  I believe these are Emgo mufflers, but I think I've seen them sold as other brands too.
Like a lot of "universal" mufflers, these have a channel on the back for channel nuts and a universal hanger strap.
That ain't gonna cut it for me, I'll dream up a better mount once I figure out how to make these fit.
Also, no way in hell am I using the adapters.  Too ugly, no seal.  Me no likey.
Started mocking them up by using household electrical wire to hang the mufflers on the bike.  The solid copper wire let me form up hangers and tie the mufflers to each other.
Blocks of wood helped hold things where I needed while I visualized what I'd need to do to mount them and connect them up to the cut ends of the downtubes.
There's just a long piece of straight tubing stuffed into the muffler here, for mockup testing.
Checking the lean angle.
More to come.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #95 on: March 08, 2016, 07:14:12 PM »
Heh I hear you brother, the rear came to me years ago for free, but the front cost a pretty penny on eBay.  Still haven't swapped in the 5-spoke front wheel yet, that'll probably happen this summer.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #96 on: March 08, 2016, 07:20:44 PM »
So once I found a setup that I liked, I decided that I hadn't butchered this pig quite enough yet and decided that the rear footpeg mounts needed to be different.  Because reasons.
Now, I'm not one to just throw things away, and it appealed to me to use as much of the original frame as possible, so I took the mounts, turned them upside down, exchanged them left for right, and found that they looked pretty keen like this.
(didn't end up using these pegs)
Attached the pieces to each other using a long threaded rod to keep them square to one another, then used rubber bands to start mocking them up.
Decided the top legs were too short, angled them back to try to match the angle of the mufflers (which was still a fuzzy target at this time).
Getting better.
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #97 on: March 08, 2016, 07:32:21 PM »
Cleaned up the frame.
Back to the bender!
You can see the beginnings of the fishmouth cuts that would be needed to make everything meet up nicely.
There was a lot of back and forth during this stage, mocking things up, tearing them down, adjusting angles, tweaking lengths, using up tons of rubber bands.
More to come
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #98 on: March 08, 2016, 07:53:34 PM »
Tacked all the pieces together
Used a square and some magnets (harvested from old hard drives) to set up some reference marks on the frame.
Prepped the fishmouths
Tacked in place
Pause for a coke and a smoke.
Hold breath, raise swingarm, check for clearance (it doesnt move this far really but it would tell me if everything was straight).
And there was much rejoicing.
Mocked everything back up....
...and hung the pipes.
So this is as far as I went at this stage.  You'll note that I'd discovered that the aforementioned block of 4x4 makes a somewhat decent substitute for the CB750 cylinder block when doing mockups, but I didn't want to lock in any more geometry until I had the real motor in the frame, so that the position of the head pipes would be more accurate.
By this time I'd also replaced the right side centerstand tab, and cut off and replaced the kickstand mount.  I know I have pics of those somewhere, trying to find them, but basically everything was put back to stock.
So at this point I was basically done making modifications to the frame and it was time to final weld everything and dress it all down nicely.
mystic_1
« Reply #99 on: March 08, 2016, 08:01:14 PM »
I'm not chopper guy, but this is cool.
