Author Topic: 77 CB 550K - ANOTHER FORK SEAL QUESTION FROM ME  (Read 1165 times)
Offline sniper1
  • SNIPER1
« on: April 14, 2010, 06:48:02 PM »
77 CB 550K
OK, I got the old fork seals out finally, that was a chore. I have the new ones to put in. Problem is they look different than the originals and I can't tell which side is up or which side is down. They look very similar from either side with only a slight difference. Does it matter which side goes up or down????
I got the seal from bike bandit. Part number 243400-001
I am so ready to put this back together and get riding again.
Offline fastbroshi
  • Puppet
Re: 77 CB 550K - ANOTHER FORK SEAL QUESTION FROM ME
« Reply #1 on: April 14, 2010, 07:06:42 PM »
The side where you can see the spring is the bottom.
Just call me Timmaaaaay!!!
« Reply #2 on: April 14, 2010, 07:11:32 PM »
Yep, be sure to polish up those fork tubes real smooth before you put it back together. Doing it twice really sucks. I know that for sure.
Offline sniper1
  • SNIPER1
« Reply #3 on: April 15, 2010, 04:14:17 AM »
I see spring on both sides, thats why this is so confusing. There is some lettering on one side, I'm thinking that might be the top????
Offline sbparks
    • My Hobby...
« Reply #4 on: April 15, 2010, 04:51:20 AM »
Sniper,
 I bought fork seals from Honda as well and you're right... Both side are open and both sides have springs.
 Here's a discussion on that type of fork seal and how to mount it:
http://forums.sohc4.net/index.php?topic=65697.0
 Basically, you need to mount the seal so the lettering is up.
 I asked questions about WHY it was necessary to do mount the seals this way.  To look at the side profile of the seal, I would have thought to mount them in the opposite direction.  I mounted mine with the lettering facing up.
 I'd appreciate any comments and being able to understand this issue better.
Scott
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #5 on: April 15, 2010, 05:33:54 AM »
On mine I put the inside profile that touches the , up, like this [ /|fork|\ ]<--seal. Kinda crude diagram. Might help. And 2nd on the clean & polish.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline sniper1
  • SNIPER1
« Reply #6 on: April 19, 2010, 03:44:37 PM »
Thanks to all on the advice!! I got them put back together and they are working perfectly. One thing I came up with to press in the new seals was some large wood clamps and a piece of PVC (1 1/2") I simply pushed them into place, replaced the clip and good to go!. I used twenty weight oil, and took someones advice to shim the springs a bit. What a difference, the thing rides even better now.
Thank you all again for the assistance!!
