Author Topic: Fun with jetting  (Read 2621 times)
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
Fun with jetting
« on: April 16, 2010, 10:25:12 AM »
So over the last little while Ive been trying out different jetting on my bike. I didnt really gauge the mileage, but its not hard to guess that its better with the smaller size. Anyway, my bike is 75 750K, unknown mileage, but runs good, doesnt smoke or burn oil. It has a 4 into 1 that could use a repack(maybe later), K&N with airbox modded a little, a Hondaman ignition, & I just put in fresh set Denso plugs a few weeks ago. Stock was #105s, I swapped in #120s last year & rode a little with them this year. I put #110s in & drilled out the top four holes in the emulsifier tubes, then retried the #120s. I just went back to the #110s, my bike seems to like them better. The #120s seemed to have a bit of an un-eveness in the mid to upper RPM range, where as the #110s are smooth all the way through. It also seemed like it was loading up a bit at lower RPMs. With the #110s its good. But, if its loading up at the lower RPMs, isnt that the slow jets? Plugs loo great with the #110s, light brown/tan and were dark grey/black with the #120s. Another good thing that came out of this is that I know my carbs are clean!
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Laminar
  • Retsam
Re: Fun with jetting
« Reply #1 on: April 16, 2010, 11:06:33 AM »
Did you do plug chops at specific throttle openings to determine which fuel circuits are running lean/good/rich? There's more to tuning than just main jets.
« Last Edit: April 18, 2010, 08:31:35 PM by Laminar »
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #2 on: April 16, 2010, 11:20:39 AM »
If it is lean with the #110; have you tried switching to the #120s and adjusting the air or fuel screws (depending on the type of carbs you have) leaner?
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline Laminar
  • Retsam
« Reply #3 on: April 16, 2010, 01:25:19 PM »
Offline JS550
  • IAFF local 1307
« Reply #4 on: April 18, 2010, 06:48:13 AM »
Didnt do a plug chop. Im not getting that far into it right now. The plugs look better with the 110s & the bike runs better with the 110s. Maybe do a chop later this summer. If I were taking it to the track I might worry more about getting every last bit outta it. But for now its running great for an old bike. I did adjust the mix screws as I went, tried different settings. Just kinda sharing my findings. But, I did have a question about what RPM the slow jets are working in? I understand there is more to tuning then jetting, but Im not looking for that last pony hiding in there! ;D Im not knocking anyone or trying for a big long discussion about tuning. No offense.
« Last Edit: April 18, 2010, 06:51:16 AM by JS550 »
Offline razor02097
« Reply #5 on: April 18, 2010, 06:36:39 PM »
Good job you can use quotes
too bad your post gave nothing constructive.
Project Rina
« Reply #6 on: April 18, 2010, 06:51:43 PM »
If you are tuning for the street by just experimenting with main jet sizes, you are kinda in self defeat mode, as the mixtures for throttle position between 1/4 and 3/4 are dominated by the slide needle position, and throttle valve jet.
FYI
Offline JS550
  • IAFF local 1307
« Reply #7 on: April 18, 2010, 08:18:23 PM »
FYI
aaaaahhh.......thats info I can use! Thanks.
Offline Laminar
  • Retsam
« Reply #8 on: April 18, 2010, 08:32:02 PM »
+0 is better than -10
Offline razor02097
« Reply #9 on: April 19, 2010, 04:13:24 AM »
That doesn't even make any sense  ???
Project Rina
Offline Laminar
  • Retsam
« Reply #10 on: April 19, 2010, 07:28:49 AM »
Which of your posts in this thread wasn't either derailing or a result of poor reading comprehension?
Offline JS550
  • IAFF local 1307
« Reply #11 on: April 19, 2010, 12:50:00 PM »
Come on guys, no bickering. Both helpful, happy riding!
Offline Ayrity
« Reply #12 on: April 19, 2010, 01:32:04 PM »
not to hijack your thread or anything, but so if I understand this correctly, I need to adjust my slide position to try to get the bit of heasitating dead spot I have around 5500rpm to go away?
1976 Honda CB550k
Offline razor02097
« Reply #13 on: April 21, 2010, 08:20:41 AM »
Sorry I just need to learn to ignore people.
I think after stock parts are replaced one tinkers with carbs forever.  I know I do.  ;D
Project Rina
« Reply #14 on: April 21, 2010, 09:56:57 AM »
I was always under the impression main jet sizing should be determined first, buy plug chops, at WOT.
up-sizing the jet and changing needle clip positions as necessary.
white plug, clip down, black plug, clip up.
once main jet size has been determined,
a plug chop is done at mid rpms to determine pilot jet sizing, and again needle clip setting.
please correct me if i'm misunderstanding the process
« Reply #15 on: April 21, 2010, 10:24:52 AM »
That's the essence of it.  The difficult part for the home mechanic is that the mixture demands change with the load placed on the engine.  More load usually requires a richer fuel delivery.
The WOT tests load the bike with whatever the rider weight is.  A heavier rider/uphill would need a slightly richer fuel delivery, as more work is required to move the specified mass.
Same is true for mid throttle testing.  But, you seldom ask for max power at a mid-range throttle setting.  Certainly maximum heat is not generated at cruise power and that effects the plug's ability to self clean.
I'm not saying it is impossible.  I'm just noting that there are more variables to juggle during the process.  The process tends to bore the tuner well before optimum settings are achieved, certainly for all but WOT settings.
It is much easier/faster to re-jet on a Dyno where the load can be varied along with the throttle position, and the exhaust can be sniffed/tested for unburned hydrocarbons.  Then you are tuning the bike only as opposed to a bike/rider combination.
« Reply #16 on: April 21, 2010, 10:31:27 AM »
thanks TT!
Offline JS550
  • IAFF local 1307
« Reply #17 on: April 21, 2010, 12:06:18 PM »
So, because Im fat, my bike needs to be richer?  ;D
