Author Topic: '66 CA77 305 Dream Rear brake Set up  (Read 3232 times)
Offline dagersh
    • Photos
« on: April 16, 2010, 04:18:48 PM »
Can anyone give me some advice on this?
My brakes work, but I canot get enough travel to get the brake light switch to engage.  I have tried to adjust the switch itself, but the linkage is completely screwed up....
thanks!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Old Scrambler
Re: '66 CA77 305 Dream Rear brake Set up
« Reply #1 on: April 18, 2010, 12:56:02 PM »
The foot-lever has to travel a fair amount to properly activate the switch..........If you say it is screwed up it may not be stock. A pic would be helpful or compare your set up to the manual.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: April 19, 2010, 08:00:00 AM »
This parts book page is the best I could come up with at the present, does it help any?
Member # 1969
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: April 20, 2010, 11:05:51 AM »
Have you tested the switch?  I have one of these (150cc Benly) and the switches seem to be pretty dodgy and prone to corrosion.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline dagersh
    • Photos
« Reply #4 on: April 20, 2010, 01:28:11 PM »
Hey guys,
Sorry it took so long to get back.
The switch works perfectly, so no problems there.  I am now able to actuate the switch with the lever, but the rear brake travel is unacceptable.  I have the "Honda" shop manual, but it is no help at all.  Sketchy translations, and dark, unclear photos.  I downlaoded the Honda Common Service Manual, but the only reference to brake set up was to align the punch marks on the brake arm with the punchmark on the wheel hub.  I have punch marks on neither....
I did come up with a photo that may be of some help.  I am going to re-spline the brake arm more perpendicular (It is angle too far to the rear), and see if that will take out the play.
I won't be able to do anything for 2 weeks, but I will update with pics ASAP.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #5 on: April 21, 2010, 07:51:39 AM »
If the arm on the brake plate looks like it is in the stock position, the 1st adjustment option is to turn the adjuster in on the actuator rod. If no more adjustment is available, moving the arm on the brake plate BACK one tooth may help. If not, you may need new brake shoes.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
