Author Topic: CB750 Fours using altered OEM frames  (Read 25629 times)
Re: CB750 Fours using altered OEM frames
« Reply #25 on: April 19, 2010, 08:47:27 AM »
I am a bit up in the air about billet covers for racing..
 Dont get me wrong I like billet stuff.
 The main concern I have is I would rather waste a point cover than break out both bolt bosses and have to weld the cases.
 I would thing Plastic covers could be vacumn formed using cheap tooling..
Offline Bill/BentON Racing
    • BentON Racing
« Reply #26 on: April 19, 2010, 08:51:26 AM »
I fully agree! ;D,Bill
BentON Racing Website
BentON Racing Facebook
Offline voxonda
« Reply #27 on: April 19, 2010, 10:03:20 AM »
Saved some ignitions, in the past, with billet covers without destroying the cases. Let's see where you come up with? Reinforced plastic could work, but the the dies are...........................bingo.
Rob
« Reply #28 on: April 19, 2010, 10:13:51 AM »
How about... Ah ....
wait a minute.. maybe i should be first to build one... ;)
Offline voxonda
« Reply #29 on: April 19, 2010, 10:38:13 AM »
Offline lordmoonpie
    • Moonpie
« Reply #30 on: April 19, 2010, 10:52:51 AM »
KOS - you should talk to Kevin (TTR400) - he seems to produce some very nice billet parts for very sensible money and clearly has a good setup capability. He might be able to do you a good labour deal out there in South Africa.
I run a much slimmer magnesium cover on my CR750 but I modified bot the crank end and use a CB350 K4 stator/rotor so it lends itself nicely to coming in a few inches. It also allows the fairing to clear the cases so you don't have to cut holes in them like some of the CR750 "replicas" out there that are way behind M3 standards.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
    • BentON Racing
« Reply #31 on: April 19, 2010, 11:07:54 AM »
Rob
Rob,your covers are beautiful and of course I'd use one ,definitely would protect the ignition.
Offline kos
    • m3racing.com
« Reply #32 on: April 19, 2010, 11:30:56 AM »
I run a much slimmer magnesium cover on my CR750 but I modified bolt the crank end and use a CB350 K4 stator/rotor so it lends itself nicely to coming in a few inches. It also allows the fairing to clear the cases so you don't have to cut holes in them like some of the CR750 "replicas" out there that are way behind M3 standards.
Yes, I remember your comments about the use of CB350 rotor and stator. Are you using the "971" part number CR kit part for this? Which was a CB350R part or are you using standard parts. Please, tell me more on how you did this?
KOS
220...221, whatever it takes.
« Reply #33 on: April 19, 2010, 06:22:29 PM »
I saw a rotor that was "said" to be a RC 750 rotor. He wouldn't cut loose with it. I know where it is but it's 1100 miles away. I can probably check it out in June and get info and pix. It did have RC Engineering stamped on it. It just didn't look like it could have been a reworked 750 piece. Possibly a 350 by RC?? Much narrower and obviously lighter. Anyone have the width/dimension of the 350 piece? This has me thinking of pairing it with a 750A field coil  ;)
Jerry
Offline moham
  • .fnord.
« Reply #34 on: April 19, 2010, 07:30:05 PM »
what...about...the...frames...?
the rest of the discussion is fascinating, though. seriously.
but I would like to know/see more about any modified-stock frames...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #35 on: April 19, 2010, 09:41:39 PM »
Sorry, we digress...............
Offline kos
    • m3racing.com
« Reply #36 on: April 19, 2010, 09:52:01 PM »
Jerry
Jerry, I have an RC Engineering rotor. What do you want from it? it is just a cut down CB750 part.
KOS
 I can send it to you if you need it.
Offline kos
    • m3racing.com
« Reply #37 on: April 19, 2010, 10:01:40 PM »
"What about the frames"
I agree, we have many other threads, so let us keep this about the OEM frames. I promise to shut up and stick to this subject.
KOS
srook
« Reply #38 on: April 20, 2010, 07:54:25 AM »
Rob,
What type of oil filter are you using on this?  Can you give details about it?
Thanks
Scott
Offline Big Bob
« Reply #39 on: April 20, 2010, 08:33:33 AM »
A nice billet or even cast cover to just clear the crank end would be best along with a thick, point side ignition cover with M3 Racing on it...would be great. I should be in the business of making these along with other billet parts very soon.
Sold!  My 836cc race bike is almost done.  I'll bolt those on as soon as they get here.  Bone stock frame, sorry.
Obligatory on-topic comment: I'm planning on having FrameCrafters do up a modified CB 750 frame for Heavyweight Superbike in the next year or two.
Offline voxonda
« Reply #40 on: April 20, 2010, 08:42:23 AM »
Rob,
Thanks
Scott
Hey Scott,
This filter is for the Honda VFR, among others.
Rob
Offline kos
    • m3racing.com
« Reply #41 on: April 26, 2010, 10:26:16 AM »
Back to the original post....here are some pics of work done to standard CB750 frame to build CR750 Kit bike....
KOS
M3Racing.com
Offline Big Bob
« Reply #42 on: April 29, 2010, 09:31:17 PM »
Mike Hodgson's CB 750 AHRMA Heavyweight Superbike machine:
Offline joehardy
« Reply #43 on: April 29, 2010, 09:40:22 PM »
Here is a photo of the Michael Hodgson's AHRMA legal Heavyweight Superbike CB750 based bike.
Note, added bracing at front down tubes and at rear where frame tubes run down to swingarm pivot. Plus... is was chromed.
Also, note dyno cover that we did here at M3 Racing HQ. Just cut out about 3" of width and tig welded a round plate to end.
Nice work... IMHO
KOS
That's not so special , I did the same with my CB750 racer already in the seventies.
I only have this picture of it , you can't see the braces on it unfortunately only the dyno cover
That picture is badass!
Offline voxonda
« Reply #44 on: April 30, 2010, 01:26:28 AM »
This is one of my all time favorite's, very clean and well made.
« Last Edit: April 30, 2010, 01:28:06 AM by voxonda »
« Reply #45 on: May 02, 2010, 08:26:37 PM »
Wow, I'll say. The more I look at that frame the more i see.  :o
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #46 on: May 03, 2010, 09:12:57 AM »
can someone please chime in on the possible negative effects of frame strengthening via gussets and downtube welding?  i've heard it can cause the frame to actually "pull" itself apart because it's not allowed to flex like it was designed to.  certain parts are more rigid leading to stress concentrations at the points of the gussets and possibly causing failure?  i've love to add some strength to mine to help the handling out as much as possible when i get around to building the frame...  good thread, great pictures!!
« Reply #47 on: May 03, 2010, 09:47:03 AM »
First lets quantify the real risk. NO ONE in my experience has ever had a CB750 frame fail. Gusseted or no. An occasional crack or weld separation is going to be within production expectations. Any one else have expereince otherwise? Was it the direct cause of something that was done to the frame, or a statistical outlier?
Theoretically, anything you do to stiffen one area will show weakness at the next point. If you can ride hard enough to feel that next weak spot, more power to you. Obviously the racer guys are on top of this.
The main points are above the swingarm pivot, the 2 spots (on each side for 4) under tha gas tank, and welding up the gusset where the headstock enters the downtubes. Quick simple, yields results, I daresay no downside. All the normal caveats about experienced welder etc. Only the biggest baddest racer with tons of HP and high banks etc. can feel problems beyond that.
Further triangulation in the area where the airbox would go, and the area between the front downtubes and above the front motormounts, would make it seriously stiff, but likely more than we'd ever notice on the street.
Or so I think.
PS: Oh yeah throw in some of Rob's motormounts!   ;D
« Last Edit: May 03, 2010, 09:50:03 AM by MCRider »
« Reply #48 on: May 03, 2010, 09:55:53 AM »
Anyone know for fact the frame is chromed?
 Almost all plated racing frames are nickle plated, not chromed...for a good reason..
Offline wannabridin
  • -Garrett
« Reply #49 on: May 03, 2010, 10:09:40 AM »
Or so I think.
what thickness flat stock are you using for your gussets??  and of course Rob's motor mounts!  i want to use anything i can from rob!!!
