Author Topic: quick question about APE trans undercut  (Read 2665 times)
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« on: April 18, 2010, 10:49:11 AM »
When I send APE my transmission to be undercut, do I send the whole counter-shaft and main-shaft assembled with their gears/bearings/circlips, etc.? If only specific gears need to be sent, what gears are they?
Thanks
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Re: quick question about APE trans undercut
« Reply #1 on: April 18, 2010, 01:02:33 PM »
Better ask them the question. I've had two gearboxes done and have sent both shafts complete with shims, circlips in place. You can remove the bearings.
Normally first gear is not undercut.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #2 on: April 18, 2010, 02:09:21 PM »
What about 4th and 5th?  They engage differently than 1st, 2nd, and 3rd.  Just curious, because I didn't undercut my 4th or 5th.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline Big Jay
    • CBRzone
« Reply #3 on: April 18, 2010, 03:37:41 PM »
Send the whole thing
Offline kos
    • m3racing.com
« Reply #4 on: April 19, 2010, 02:06:21 PM »
Jay, After APE is done with undercutting the dogs on these gears, do you send back for reheat treat? I have found once you have back cut the engagement dogs, you loose life in these gear sets as you have removed the hardness...and always need to redo periodically?
Thanks in advance for your advice.
KOS
M3 Racing USA
220...221, whatever it takes.
Offline Big Jay
    • CBRzone
« Reply #5 on: April 21, 2010, 07:44:16 PM »
Depending on the depth of the case, some require re-heat treat.
« Reply #6 on: April 21, 2010, 09:08:28 PM »
 I've seen hardweld repairs though they need heat treat too IMO. Price of heat teat is up....especially in CA with tax on everything. That's my understanding after talking to a cam company the other day.
Offline kos
    • m3racing.com
« Reply #7 on: April 22, 2010, 07:04:27 AM »
Hardcase... that is.
Thanks for details.
KOS
Offline kos
    • m3racing.com
« Reply #8 on: April 22, 2010, 07:25:21 AM »
The only cams I ever race with are NOT billet, but hardweld as they end up have a surface 3-4 times harder and more durable than billet or even OEM cam surfaces. When visiting Jim Dour at Megacycle and getting the tour, I was amazed to see a room full of welders... gas welding the extra material onto the cam lobe areas, then off to cam grinding machine, heat treat and then all have to be straightened, as the welding warps them. That is why they cost so much. I have had times when a lack of oil to cam has caused some scoring and we  just took off the scoring with fine sand paper and reinstalled..never had a cam related problem after.
Having the same problem with a billet cam, and we were done if that happened.
Street bike, big bore stuff for street, billet works fine but for all out performance...go with hard weld. Also, we like to change lobe separation....from billet cam specs. And there are also over 20 cams, in the not for public viewing megacycle cam book for CB750 SOHC's.
KOS
« Last Edit: April 22, 2010, 10:35:24 AM by kos »
« Reply #9 on: April 22, 2010, 09:30:59 AM »
Street bike, big bore stuff for street, billet works fine but for all out performance...go with hard weld. Also, we like to change lobe centers from billet cam specs.
KOS
Do you mean lobe separation Mark??
Offline kos
    • m3racing.com
« Reply #10 on: April 22, 2010, 10:33:14 AM »
KOS
Actually, lobe separation angle (LSA)
KOS
« Last Edit: April 22, 2010, 10:53:06 AM by kos »
