Author Topic: Put new clutch in my 76K have questions?  (Read 868 times)
Street 540
« on: April 18, 2010, 03:24:04 PM »
I just got done putting a new barnett clutch in my K6. I made adjustments to both ends of the clutch cable but it clunk's into gear when standing putting the gear selector from netrual to first or second gear. Seems to release fine and works fine going down the road. Could my clutch disc be in the wrong order? Replaced clutch disc,plates,springs and cable
Offline petescb
Re: Put new clutch in my 76K have questions?
« Reply #1 on: April 18, 2010, 07:56:02 PM »
Barnetts are notorious for not having flat clutch plates.  Try the stock Honda clutch.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #2 on: April 18, 2010, 09:33:40 PM »
I thought they all went "ker-lunk". Mine does. New clutch - standard Honda.
Offline the technological J
  • deliciouso!
« Reply #3 on: April 18, 2010, 09:45:01 PM »
i would try to tighten the clutch setting a little... it sounds like your clutch is till transferring power to the gears(which is why it clunks as it slams to a stop).... so see if u can have it a little looser of a setting...... which i think is tighter on the adjuster....... but hold tight and wait for the pros to answer
94 ST1100..Gone
72 750 K2 Stay tuned!
j-no
« Reply #4 on: April 20, 2010, 02:04:21 PM »
I wanted to bump this topic because i just swapped for a Honda clutch in my 75 750F and am having the same problem.  In the clutch that I removed there was a doubled up clutch plate after the third friction disk.  The clutch that replaced the old one did not have this doubled up clutch plate.  I put the new clutch basket together without the double because the pressure plate wouldn't seat inside the clutch center with it.  Any ideas?
Not trying to hijack you thread Street, just thought we may both get some answers/attention from the pros
Offline nancy
« Reply #5 on: April 20, 2010, 03:52:20 PM »
This could be the Honda field fix from that era (Honda US Service Bulletin) - they advocated fitting an additional disk - actually from a GL1000 I think, to alleviate clutch chatter.
Hinomaru
« Reply #6 on: April 20, 2010, 04:08:51 PM »
Here's the Honda bulletin that shows both the field and factory fix. Note the engine numbers for the K and F models.
http://data.sohc4.net/Clutch_rattle.jpg
Street 540
« Reply #7 on: April 21, 2010, 12:00:14 PM »
No worries, Thanks for the input. makin sure I wasn't scewing anything up.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=12p28s1c6gru79vprdkp0jnck6&/topic,60973.0.html
« Reply #8 on: April 21, 2010, 12:17:04 PM »
hey ,,sorry to hi,jack again,,hvat setup vorks best..normal plates or that vhit that steel plate,,have dhat steel plate in my 550,,but are to thance to normal friktions plate..it give one more friktion plate vitaut that metal plate in..
i hate all this v-w.... vords
