Author Topic: K2 Seat on a K8?  (Read 683 times)
Offline Wisconsin Jeff
K2 Seat on a K8?
« on: April 18, 2010, 03:43:18 PM »
I recently picked up a K8 with a roached out seat and a dented tank.  I have a buddy that will sell a K2 seat and seat for $80, both in decent shape.
I understand that the hinges were on the opposite sides as well as the latch.  The tank drops right on but the petcock is on the opposite side.
I just need a little guidance about the seat fitment.  I don't think it would be a huge issue to drill and use some self-tappers for it to sit on there.  But am concerned about how it would fit to the frame.
Has anyone had any experience with a conversion similar to this?
Offline Nikkisixx
Re: K2 Seat on a K8?
« Reply #1 on: April 18, 2010, 05:07:28 PM »
As you said, the tank is no big deal.  Just remember you only need one fuel line from the tap, so you may need to block one off.
If you can weld, moving the hinges is fairly easy as well.  Maybe some rivets if welding is not in the cards?  Can't help much with the seat retrofit because I used a '78 seat and adjusted to fit with a '72 tank.
Offline MasterChief750
  • Detonation
« Reply #2 on: April 18, 2010, 07:16:20 PM »
tried to do the self tapping myself and it was a royal pain in the @$$. cound not get it to sit right and screws would not support the weight of the seat and would rip out if you opened it and moved it into the vertical poistion. and if i remember correctly the earlier seat pans may be a little bit skinnier.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
