hijack!
am working thru a similar situation, and followed all avenues that have been suggested in various posts i have seen regarding one cyl running rich. prob carb is #4.
carbs cleaned and benched synch'd, new plugs, replaced #4 resist cap w/new NGK 5 ohm (previously had huge number of 80.2, not 5 ohm), valve adj re-checked, set timing at "F", dwell set at .016 because i ran out of plate adjustment, verified advance is working using timing light, relative compression is good, cam chain tensioner re-checked ok, re-set this float from 16mm to 14.5mm, re-checked this emulsion tube (still perfectly clean), adjusting air mix screw has no effect. not sure what i am missing but i'd next like to check the "side wall of the seat" for corrosion/wear.
can someone point me in the right direction to find an exploded view of the pd-46a carb showing interior components? need to find this "seat", and which "o"-rings are you referring to? many thanks!
bobp
77cb550k w/pd46a carbs, oem 4/4, pods
mains - 105
slows - 42
clip pos is 4th down from top
needle is e2350f
floats set to 14.5mm
air screws on #1 - #3 is 2t out. plugs look nearly perfect
air screw on #4 is now 1t out, still very sooty
bike idles fine at 2000, all pipes evenly hot, plugs have identical spark when viewed in darkened "shop", pulls very strong to 8000, no steady-throttle hesitation anywhere, no popping on decel, pretty quick little bike. thx!
bobp
