Author Topic: Removing rust from a cam.  (Read 896 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« on: April 18, 2010, 09:46:45 PM »
A friend gave me a cam and ported head a few years ago, thinking of running it on the '77F w/836 kit. Cam has A LOT of rust on it, but appears to be surface flash. How can I clean it without mucking up the lobe faces? I may end up getting it polished if it is more than flash, but I'll go down that road only if I have to.
Thanks,
Gonzo
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline ealanm
Re: Removing rust from a cam.
« Reply #1 on: April 18, 2010, 10:02:06 PM »
I don't know about rust, but I've had success with some pretty gnarly cams using the following method.
I put a long M8 cap screw in the end, so that I can hang the cam from the chuck of my drill press.  I have a plastic cap that fits nicely in the hole in the drill press table and also fits nicely over the journal at the other end of the cam.  I can't recall the exact RPM I use, but it's a medium speed.  I start with 600 grit emery, cut into strips slightly wider than the cam lobes, and WD40.  That takes the roughest stuff off.  Once I'm down to smooth metal I clean off all the WD40 and grit.  Then I switch to jeweler's rouge and a soft cloth.  For the jeweler's rouge I up the RPM -- but watch the fingers, you don't want that cloth to get tangled while your holding onto it!  The jeweler's rouge gives a pretty good finish, which I've used as-is, but you can move on to Brasso or other metal polish if you want a really good job.
Once all that's done, make sure you give it a really good cleaning to get rid of any remaining grit.  Varsol does a good job of taking the jeweler's rouge off.
"Speed, it seems to me, provides the one genuinely modern pleasure."
--Aldous Huxley
Offline Big Jay
    • CBRzone
« Reply #2 on: April 21, 2010, 07:45:45 PM »
Clean it up with navel Jelly
