Author Topic: Looking for Ignition Ideas  (Read 9474 times)
Offline ealanm
« on: April 18, 2010, 10:07:27 PM »
I'm running a CB750K2 engine in a vintage race car.  It currently has stock ignition.  I want to upgrade the ignition system, and I'm looking for suggestions.  Ideally, I'd like something based on technology that was available in the early 70s, to be vintage authentic, but I might consider something more modern if there was a good enough reason.  Thoughts?
"Speed, it seems to me, provides the one genuinely modern pleasure."
--Aldous Huxley
Re: Looking for Ignition Ideas
« Reply #1 on: April 18, 2010, 10:30:30 PM »
I don't think you are going to find much from the early '70s. I have a '77 Cycle magazine article that details the use of 4 automotive coils for 4 cylinder bikes, at the expense of point life. There were home-brew CD type ignitions, that used points for triggers (like Hondaman's??), that might be just what you're looking for..
« Reply #2 on: April 18, 2010, 10:36:26 PM »
 A Dyna 2000.
« Reply #3 on: April 18, 2010, 10:46:29 PM »
Did Dyna date back to the early '70s? (I never heard of them until I joined this forum.) I have a Gerex electronic that dates to at least the late '70s that works very well.
Offline MaaseyRacer
    • Fuelist
« Reply #4 on: April 18, 2010, 11:12:38 PM »
Cycle X?
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« Reply #5 on: April 19, 2010, 12:28:05 AM »
Martek 440 is a vintage techie ignition.
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #6 on: April 19, 2010, 04:46:28 AM »
What about HONDAMAN ignition?
Found real friends here !!!
« Reply #7 on: April 19, 2010, 08:35:02 AM »
You would be happy with a Maxi-Dwell..
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #8 on: April 19, 2010, 08:59:53 AM »
+1,000,000!  i love my hondaman ignition.
Mark Twain - Notebook, 1894
Offline kos
    • m3racing.com
« Reply #9 on: April 19, 2010, 11:36:09 AM »
I'm with Mike on this Get over the Classic aspect and get a Dyna 2000 or at least a Dyna S! The Dyna S hides under standard point cover so they will never know!
KOS
220...221, whatever it takes.
Offline BLUE71TURBO
« Reply #10 on: April 19, 2010, 12:29:25 PM »
 A.R.D. MAGNETO IGNITION.
Offline kos
    • m3racing.com
« Reply #11 on: April 19, 2010, 12:57:13 PM »
Mags are nice, but in this period...no advance was Incorporated so they were notoriously hard to start without a lot of pushing or rollers. And they had POINTS!
KOS
Offline BLUE71TURBO
« Reply #12 on: April 19, 2010, 01:46:28 PM »
 The first A.R.D. magnetos had locked in full advance like this.........
 The next style was like this with full advance locked in ............
 The last style was a C.D.M. A.R.D. Magneto. It was a ( Capacitive Discharge Magneto )  Which is an electronic pickup setup, no points
 and it has a toggle switch to lockout the advance so startup is real easy. After startup you switch to run and off you go.   ;D
 Here's a picture of a C.D.M. A.R.D  magneto that I picked up for a KAWASAKI. No points and notice the toggle switch on the top to
 lockout the full advance at startup. Yes, the first A.R.D. mags were a #$%* to start. Especially when they kick back !!  :o
 This is the same setup i run on my turbo'ed 750   ;D
Offline kos
    • m3racing.com
« Reply #13 on: April 19, 2010, 02:02:29 PM »
Is that bottom bike a turbo with a Solex cabB?
KOS
Offline ealanm
« Reply #14 on: April 19, 2010, 02:09:51 PM »
Thanks, everyone, those are some great ideas.  That magneto system would be very cool for vintage racing.  I know mags have their drawbacks, but if my objective was to avoid drawbacks I wouldn't be racing vintage, would I?
--Aldous Huxley
« Reply #15 on: April 19, 2010, 07:34:40 PM »
KOS. its an SU CV carb, good chance its from Rivera Engineering.
I think the guy that stsarted this topic wants a real period ignition..  to keep in the spirit of what he is doing. I am sure if you say 70s it includes the early Dyna models..
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #16 on: April 20, 2010, 11:23:07 AM »
The best you can get , but it's modern:
ELZ = German
 http://doc.honda4.nl/elz2coil/Ignition%20En%20rev%20b.pdf
« Last Edit: April 20, 2010, 11:31:32 AM by Howell »
You meet the nicest people on a Honda
esw07
« Reply #17 on: April 20, 2010, 01:34:02 PM »
This might be a little bit more simplistic of a solution, but try double springing your points, that is if you want to stick with the points and save a few bucks over an A.R.D. ignition or the likes.
Double springing will take out a bit of the flutter that these tuned engines get at higher rpm's. Heres a link to an article that goes more in depth with the concept, plus it works great if you're on a budget.
http://www.motorcycleproject.com/motorcycle/text/sohcign.html
« Reply #18 on: April 20, 2010, 06:52:42 PM »
Go for the magneto! They do have advantages, too: as RPM goes up, so does spark energy, unlike a regular coil system.
« Reply #19 on: April 20, 2010, 07:12:09 PM »
Speaking of period mods, you may want to try Webers..
 What do you run for carbs..?
« Reply #20 on: April 20, 2010, 07:48:55 PM »
10+ for Webers: I believe the setup data that I posted on this forum was based on your type of racing, ealanm. I extrapolated the data for 1 liter motors to an 836, that revved higher..
Offline Big Jay
    • CBRzone
« Reply #21 on: April 21, 2010, 07:43:03 PM »
A Dyna 2000.
Yep. Nothing else is available that makes more power.
« Reply #22 on: April 21, 2010, 09:11:12 PM »
ELZ = German
have you thought about reducing the length of those CR adapters?
Offline kos
    • m3racing.com
« Reply #23 on: April 22, 2010, 07:16:06 AM »
A Dyna 2000.
And is so tune-able !
KOS
Offline ealanm
« Reply #24 on: April 22, 2010, 09:19:40 AM »
The engine that it's in it now is all stock, including the carbs.  But I'm building up a vintage race engine that has Hilborn fuel injection.
--Aldous Huxley
