Author Topic: CB750 Neutral Shift  (Read 1408 times)
Offline joehardy
CB750 Neutral Shift
« on: April 20, 2010, 07:29:34 AM »
CB750 does not like shifting to neutral with engine running- goes directly to 2nd from 1st and takes a bit of force. With the engine not running it shifts very easily to neutral from either gear. Is this typical for the 750?
Offline Gordon
  • 750K1, 550K2
Re: CB750 Neutral Shift
« Reply #1 on: April 20, 2010, 08:58:55 AM »
No, that's not typical.  Sounds like you need to adjust the clutch.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: April 20, 2010, 09:01:56 AM »
+1 adjust the clutch lifter and the two cable adjusters as per the manual.  If that doesn't cure it, it could be warped clutch plates, or a bent or worn shift fork.
mystic_1
- John Augustus Shedd
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 20, 2010, 09:11:54 AM »
Also, all of my bikes shift much easier with fresh oil.  Old oil isn't going to cause that problem, but it will make it worse.
Offline joehardy
« Reply #4 on: April 20, 2010, 03:18:57 PM »
Thanks, the clutch adjustment seemed to help a bit. As a follow on, how much travel should there be at the clutch lever between disengage and engagement. Mine seems to be a fairly small window and it's toward the lever being fully released- seems like the clutch does not engage till the lever is almost fully released.
Offline Wisconsin Jeff
« Reply #5 on: April 20, 2010, 05:10:37 PM »
My issue has been resolved.
http://forums.sohc4.net/index.php?topic=68841.msg761025#msg761025
Main problem- Thrust washer was installed in wrong order under clutch hub nut.
Contributing problem- One out of spec (warped) steel plate.
I adjusted the clutch lifter using the correct procedure outlined in the manual as well as the cable adjuster by the cover as well as on the handlebar.
Clutch friction zone closer to the fully released position is normal.
Clutch free play spec is 10-20mm at lever.
Thanks Mystic!
