Author Topic: Anyone know what the last 2 digits on a standard Honda part number means?  (Read 871 times)
Offline markb
  • When I finish my current project I might be a
By standard part number I mean like nuts and bolts.  For example, in the part number 92000-08040-0A,  92000 means its a hex bolt and 08040 means its an M8 x 40mm long.  I know the -OA is some kind of finish or material designation and that's what I'm trying to find out.  I've seen -0A, -0B, -02, -0S, -4J, -3B, -49 and maybe some others.  I've compiled a list of all the fasteners on sandcasts and k0's and it was looking to my like -0B was a plain hex head (no "8") but I've seen that suffix on the pan head screws too.  This info would be helpful when working on restorations.  Anyone?
Thanks,
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Johnie
Not sure if this will help mark?
http://www.oldmanhonda.com/MC/HCodes.html
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Old Scrambler
Honda changed the codes several times from '67 into the '70s mostly due to designating strength and making sure the mechanics used the correct fasteners that had changed thread pitches since 1966.  Some of the codes are superceding parts meaning its improved and should be used. In your case, a true restoration would require the original item code.  The sandcastonly group has IDs for every fasterner on the earliest bikes. After about #1500 they became much more standard.  Some of the parts codes also ID for chrome versus zinc versus black.
The little 8 is prevalent but a few heads are smooth instead of recessed on these bikes. If its of any help, I have a late production K0 that has never been apart. I could ID any head you need.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline markb
Thanks Johnie, that link has some good info but nothing about the suffix definitions.
...The sandcastonly group has IDs for every fasterner on the earliest bikes...
I looked on their site but didn't find anything.  Could you steer me in the right direction?
I might take you up on that.
Even the washers drive me crazy, especially after complete disassembly and replating.  There's over 30 different flat washers on sandcasts and early K0's with many variations on the OD and thickness for the same ID.  I finally made a list of all of them and where they go and what size they are.  The most prevalent are the M6 & M8 form B (thin) washers.  I just buy them in bulk instead of bothering with replating because they are usually junk anyway.
Mark
