Author Topic: 72 cb750 pops out of 1st (now fixed )  (Read 1792 times)
a4x4spit
« on: April 20, 2010, 09:49:30 PM »
hey Im new here had my cb since 1976 and kept it I had a problem with the trans poping out of second  gear ,so I got a suposidly good lower end & trans so I swapeed upper end & electrics from my bike to the new motor put it all back together & the new motor/tranny pops out of 1st gear now.( just Ideling on center stand it pops out & wont stay in under load either  ) my question is is there a common cause for this (and/or the 2nd gear) issue  problem Im hoping between the 2 transmissions I have I can get one that works I guess tomorrow Ill split some cases to see whats there any advice will be apriceated
« Last Edit: April 22, 2010, 11:00:11 PM by a4x4spit »
Re: 72 cb750 pops out of 1st
« Reply #1 on: April 20, 2010, 09:53:09 PM »
Popping out of 2nd is often a worn set of dogs on the C5 gear, while popping out of 1st is often either a bent shift fork or damaged shift drum (look closely in the fork groove on the drum).
a4x4spit
« Reply #2 on: April 20, 2010, 10:13:09 PM »
I spent all day putting the bike together & getting it running  then finding out it pops out of 1st and tearing it apart again ready to lift out again tomorrow. I read a 11 page post about spliting cases & trans problems  I have a set of shift forks & drum I bought on ebay before I stumbled on the "GOOD"lower end thanks for the response
a4x4spit
« Reply #3 on: April 21, 2010, 06:22:30 PM »
got the cases split & the only thing that stands out is a slot on the shift drum looks warn its not the same as the new one I have thats for sure and it seems to make sense when I see how the drum moves shift forks does this look like it could be the cause of poping out of 1st
« Last Edit: April 21, 2010, 06:34:17 PM by a4x4spit »
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #4 on: April 21, 2010, 06:24:15 PM »
popping out of 1st is easy to fix. leave your foot on the shifter. ;D
a4x4spit
« Reply #5 on: April 21, 2010, 06:35:48 PM »
thought of that &it didnt work
« Reply #6 on: April 21, 2010, 09:24:23 PM »
Check the fingertips on the shift fork, too. They might be scarped up and burned. Or bent a bit. If you have another newer one, now's the time to change it!
a4x4spit
« Reply #7 on: April 22, 2010, 12:22:00 AM »
I do have a shaft with shift forks that came with the new(er )drum that Ill put in tomorrow it really helps to know where to look
a4x4spit
« Reply #8 on: April 22, 2010, 10:58:41 PM »
I got the bike all back together and it seems to work fine on the centerstand(which it did not before )....MAN that is a long days work . I replaced the shifter drum & shift forks & shaft I also put all the gears that attached to the shift fork toward the middle of the engine the dogs looked a little rounded off  which  ment taking apart my other  engine 's lower end and swapping some gears  ;D  .. Ill take it for a ride tomorrow .. thanks for the info  HondaMan  Ive had this bike since I was 17 and am going to keep it going
« Reply #9 on: April 23, 2010, 06:00:18 PM »
Cool, 4x4!
Ride on!
I've had mine since I was 20.  :)
