I've started making plans for painting!
Bought a brand new paint gun yesterday from Amazon, and it looked like a solid deal!! This is a 1.7mm all Aluminum and Nickel spray gun, with a 600cc canister, pressure valve, and 40 PSI, average air consumption: 4.5 CFM... which is okay, I was looking for something sort of low powered, I want to do good even layers, and ensure no running....
I'm having a friend whip up a design from scratch that will be some sort of tribal or celtic stripe running from the front of the tank, to the back where it meets the seat. Going to be Black with silver design.
And, going to do an engine design where the whole engine is black, except for the outside edges will all remain silver, giving it a pin-stripe effect.
Originally I was going to use powdercoat (because it's awesome!) And then, thinking back to my time at a paint factory I remembered that the best powdercoats require about 400 degreesF of heat... so, that kinda shot that idea, so I'm going to use a Urethane based paint, and going by the book on activators and thinners to give it all a good shine. I figure on this being my plan (depending on paint quality) 1 layer primer, 3 layers base, 1-2 layers clear coat.
Painting rims either all Silver, or Black with Red pinstripes.
I also sort of want to paint the exhaust system, since when all is said and done, I'll have welded the pipes, and I don't want them to look tacky, so I thought that a good way to go is black painted exhaust with Gray Sleeves.
I know a lot of people think a mostly black bike is overdone, but I think it's a very solid look for this style of bike, and I think the silver flares will make it pop!
Thoughts?
