Author Topic: Title scare! Is my bike stolen property?  (Read 2933 times)
Offline Wisconsin Jeff
« on: April 21, 2010, 11:50:45 AM »
I recently picked up a K8 with a clear title.  I never bothered to check to see if the numbers matched.  After about a month of it sitting in my backyard I decided to do so.  I was shocked to realize that the number stamped on the frame and the # on the title were completely different.  I looked up the number and realized that the number on the title was actually the engine number.
It was last titled in Wisconsin.  I made a few calls, one to my local Honda dealer, to see if anyone heard of this.  I discovered that when the MSO came from Honda they stated the engine number on the documentation.  The WI DMV decided that the engine number was sufficient.
I guess everything is fine, but I was a bit shocked at first thinking I had a hot bike.
« Last Edit: April 21, 2010, 11:52:21 AM by jf818 »
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
Re: Title scare! Is my bike stolen property?
« Reply #1 on: April 21, 2010, 05:41:07 PM »
The engine number and frame numbers never match - it's a long story that probably makes sense to someone, but that's how they did it.  With that being said, the frame number is usually what the bike is titled under.  But hey, if you have a clean title and registration then ride on!!!
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline Caseygroh1
« Reply #2 on: April 21, 2010, 11:15:53 PM »
yep, wisconsin uses the engine number. you're fine.
74 CB550
75 CB550 cafe project
Offline JLeather
« Reply #3 on: April 22, 2010, 01:03:46 PM »
Yeah, that's a Wisconsin thing.  No problems man.
Offline SHELLFISH
« Reply #4 on: April 22, 2010, 01:59:53 PM »
That's bizarre that Wisconsin use the engine number and not the frame number!
The frame and engine number are usually pretty close but in CT that's not close enough!
Glad to hear you are OK! I would be having psych problems for a while if that happened to me here!
I want to die like my grandfather did...in his sleep and not screaming like the passengers in his car!
Offline Old Scrambler
« Reply #5 on: April 22, 2010, 05:53:58 PM »
Its not just Wisconsin..........I have several out of state titles to the motor ID on other bikes.  All HD products were titled to the motor until 1978 or so....they did not have frame numbers.   One advantage to the mixed system is that if you have a bike with no title, you could buy a motor with a title from Wisconsin, or the other way around...........Anyone out there with a frame or rolling chasis and a title?  I have a few motors without titles.....two don't even have numbers.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #6 on: April 22, 2010, 11:54:30 PM »
I guess I can kinda understand that as alot of builders use custom frames it would make more sense to title the engine.  I do have to wonder though how many people have not realized this and done a motor swap....  :o
1975 CB750K
Project Back in Black
Offline Johnie
« Reply #7 on: April 23, 2010, 06:18:11 AM »
I had a deal here in WI last year when I bought my K4 from a WI owner. Had a hard time checking the VIN with the dirt on the motor but it looked correct. Once I got it home and could spend some time cleaning I found 1 number off on the engine ID compared to the VIN. I called the DMV and they ran the number on the title to find out it was not HOT. So they said to just send in a picture of the engine number with an explanation of the problem. Took only a month and I got the title all squared away. But yes, it does give you the willies for a while...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
