Author Topic: side cover stripping question  (Read 11828 times)
Re: side cover stripping question
« Reply #75 on: April 15, 2017, 06:06:27 PM »
Go to Supercheap Auto and buy some VHT or Holts brand plastic primer mate, it's designed to stick to flexible plastic parts, and if you've scratched up your sidies, get some high build primer of the same brand.
Once you've primed it, mist a coat of contrasting color over the primer, let it dry, then wet rub it back with 600 grit with a drop of dishwashing detergent in the bucket of water. The contrasting color will highlight all the scratches etc, and allow you to rub them out. This is called "Color Sanding".
More high build primer might be required to fill all the imperfections, or you can buy a tube of scratch filler if necessary. Cheers, Terry. ;D
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
« Reply #76 on: April 15, 2017, 09:29:00 PM »
Thanks Terry!  8)
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
