Logo merchandise is available at the SOHC/4 Shop
Quick stupid question. One does not use "hondaseal" when using plastiguage to size bearings, correct?
Quote from: MattFreeman on April 23, 2010, 07:08:20 AMQuick stupid question. One does not use "hondaseal" when using plastiguage to size bearings, correct?That's right. Upon final assembly, with the torque thats rendered upon the main bolts, the HondaSeal is squished to molecular levels.Even on final assembly you won't be putting HondaSeal around the mainbearing holders, just the periphery of the cases.
I have always used 1104 /1194 on the pillars. I apply sparingly and keep it about .040 (1mm) away from the bearing edge. This is standard procedure in most Japanese motorcycle service manuals
