Author Topic: Advice? Tight pistons on rebuild  (Read 1345 times)
SandwichEnthusiast
« on: April 23, 2010, 08:49:47 AM »
Can I get some advice?
So, I just put the cylinders on the pistons today after having the cylinder bored and honed to .25 oversize: new pistons new rings new pins new clips.
I cleaned the honing compound off real well, blew it dry, oiled up the walls, was really careful about the ring gap etc.
And I feel like it's turning over really tight: I can turn the rotor with some effort, and there is some noise, but it isn't scratching the cylinder walls or getting caught.
(video if anyone's interested)
http://www.uoguelph.ca/~ibaran/ian%20motor%20002.avi
SO, how tight is too tight? Is my engine going to seize on startup? I don't know anything about anything, so I have nothing to compare it to.
Thanks a lot,
Ian
Offline Old Scrambler
Re: Advice? Tight pistons on rebuild
« Reply #1 on: April 23, 2010, 08:57:30 AM »
Hopefully you sent the pistons and rings along to the shop for the re-bore so they could match them. When they were returned each piston should be marked to match the barrel number.
The rings will fit snuggly against the wall and at TDC will be somewhat compressed = pressure!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: April 23, 2010, 09:19:59 AM »
are there sparkplugs in the head yet?
Mark Twain - Notebook, 1894
SandwichEnthusiast
« Reply #3 on: April 23, 2010, 09:32:37 AM »
No, I'm still putting it back together, the cylinder head is off, I just put the cylinder back on.
