Author Topic: How to print gauge faces???  (Read 4867 times)
Offline Kouros
    • DOUBLESTRIPES.COM
« on: April 23, 2010, 12:14:07 PM »
How can I use my inkjet printer to print gauge faces? What media do I use?
I'm not concerned with template or cutting it.
I'm looking for either a sticky-back (or otherwise normal paper/media) that will not fade away from UV rays. Also, would the light come through the gauge at night if I stick anything on top of existing gauge faces?
Thanks.
-K
1974 CB750 K4 (Re-build in-progress)
Offline Kouros
    • DOUBLESTRIPES.COM
Re: How to print gauge faces???
« Reply #1 on: April 23, 2010, 01:07:45 PM »
I found some annswers already through searching deeper.
So vinyl was recommended vs, photo paper. I guess I'd have to test print for size and just go to local sign shop for putting it down on vinyl.
But question remains: would the be light...........coming through any of this?
-K
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: April 23, 2010, 01:14:20 PM »
The gauges are back lit, they are translucent like auto gauges.
Offline ieism
« Reply #3 on: April 23, 2010, 03:20:45 PM »
I'd have to disagree with the last two posts. The gauges are not backlit or translucent. Light simply shines on it from the sides. At least on 550's this is the case.
And having vinyl printed is not per sé better than printing a good quality inkjet photo yourself. I have bit of experience in both vinyl printing and screenprinting, and do a lot off proffesional printing for clients right now.
If you (or a friend) have a recent inkjet printer, and buy some good quality paper, they will not fade for at least 50 years and look great too. Epson has vinyl that goes in regular inkjet printers for my printer, i'm not sure if they have it in smaller sizes too (my printer use 44" rolls). But for my own gauges I used Ilford Pearl and glued it on with spraymount.
Just go to your local photographic supplier and buy a testpack with different types of paper for a few dollars and make some tests. I suggest not using fibre based or photo rag papers because they might absorb water/moist.
---cb550---
Offline 333
  • Time for change
« Reply #4 on: April 23, 2010, 05:02:44 PM »
IndustrialCafe has done it.  He did gauges with LEDs and printed new dials.
http://forums.sohc4.net/index.php?topic=67321.0
« Last Edit: April 23, 2010, 05:04:45 PM by 333 »
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Laminar
  • Retsam
« Reply #5 on: April 23, 2010, 05:56:41 PM »
Hate to break it to you, but...
Offline MaaseyRacer
    • Fuelist
« Reply #6 on: April 23, 2010, 06:08:50 PM »
Talk to a local sign shop.  You will be amazed who can do what with what, and for relatively little cost.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
