Author Topic: 1975 cb 550 build  (Read 2506 times)
Offline luap
  • LAWL
1975 cb 550 build
« on: April 23, 2010, 08:12:27 PM »
 I picked up my 1975 cb 550, found it on craigslist for 1000.00 bucks it was a runner but needed alot of work, def need to find a cheaper one next time, I picked it up about 2 months ago, 2nd day I had it the tear down started, being a noobie it took me a little while to figure everything out but once  got started it rolled pretty smooth, lot of simple green toothbrush scrubbing, 400 grit sand paper, steel wool, mothers polishing compund elbow grease an a polishing wheel an its turning out pretty nice,
Once i got it to the look i wanted it I began the parts order an the rebuild,
some things Ive done to it so far, painted wheels gunmetal with a silver flake),new brake piston,new challenger tires an tubes, painted speedo an tach, frame painted black with a metallic silver clubmans, custom bar clamps(cut out the dummy lights in between the bar clamps) asv (f1) cluth lever with pearch 2009 crf 450 master cylinder asv brake lever, (need new braided brake line but being cheap an running the old one) painted fins on motor flat black, new grips all new cables, new gaskets through out, rebuilt carbs( up the mainthe main  to a 110 have a 40 pilot on order?) 4 into 2 exhaust came on the bike but painted it a flat silver tone, put some new shorty mufflers on it, waiting on My gp race tank from roc city cafe an dunstall seat an cowl, rewired bike with a simple wiring diagram I found, gonna be kick start only, headlight is on a switch,Running a single uni filter(used the set up i saw on here from another member) with stock plastic piece that mounts to carbs its coming along. some thing I need to get it road worthly. need to sync my carbs, seems to be firing good but will recheck the timing an firing,check the rocker arms im getting the tapping noise from the rockers,tighted tach cable needle is bouncing a, adjust clutch cable, weld up a battery box an mount electrical, (waiting on tank to see where to mount itmake license plate bracket wire brake light , get it to pass emmissions  get new registration. hers a link to my photobucket  an the bike thanks.http://s924.photobucket.com/home/luap_dr
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline sinister902
    • Anger Street Kustoms
Re: 1975 cb 550 build
« Reply #1 on: July 16, 2010, 11:56:08 AM »
if you dont mind me asking, where did you order the 40 pilot mains from? I am in the process of tuning the carbs on my '75 cb550 and need to upgrade the pilot jets.
Offline harisuluv
« Reply #2 on: July 16, 2010, 12:07:54 PM »
I saw this bike on craigslist.  Guy wanted $5000 and then after not selling he changed it to $3500.  That was the last I saw of it.  Guess he dropped the price again huh?  ;)
