Author Topic: Do I want the trans installed when sizing crank bearings?  (Read 490 times)
Offline MattFreeman
  • What Have I Done?
« on: April 24, 2010, 06:34:40 AM »
In case you can't tell I nervous about this procedure and dragging my feet alittle.
Do I need the rest of the "stuff" installed in my cases when sizing bearings with plastiguage?
I know It is recommended that you have the rods installed on the crank, is it truly necessary to getting a accurate measurement? What about the trans bearings and trans, k-start, ect?
Any advice or words of encouragement would be greatly appreciated.
Thanks
Offline KRONUS0100
  • MAD MATT THE MANIAC
Re: Do I want the trans installed when sizing crank bearings?
« Reply #1 on: April 24, 2010, 06:45:57 AM »
all you need is the crank in place to size the main bearings.  only have to install the rods as you size each rod bearing.
MATT
