Author Topic: 836 ring compresssion need help !  (Read 728 times)
Offline Bill K
  • 78 750k
« on: April 24, 2010, 01:04:37 PM »
 Im trying to get my block back on and we are having one hell of a time trying to compress the rings. Any help greatly appreciated. Did the search but cramped for time, got my dad over helping now.  Thanks !
Re: 836 ring compresssion need help !
« Reply #1 on: April 24, 2010, 02:51:14 PM »
Hopefully you have #2 & #3 up with #1 & #4 down. Support the 2 "up" pistons with something like a pair of 2 X 2's front and back to keep them up and not moving. Bring the cylinders down onto the pistons. Squeeze the rings and wiggle the cylinders down over the rings. Some do the ring compression by hand while some use ring compressors. Once you have these 2 pistons inside the cylinders you have to turn the crank to bring up #1 & #4 then do the same. Simple concept but harder the first go around.
Offline Bill K
  • 78 750k
Re: 836 ring compresssion need help ! Update got em
« Reply #2 on: April 24, 2010, 03:31:10 PM »
 Thanks, we got em. What a pain in the a$$ !
« Reply #3 on: April 24, 2010, 05:32:57 PM »
 You should always check ring gaps before installation. Not to sound like Mother Hen BUT I recently ran into a ring problem with an aftermarket set.
« Reply #4 on: April 24, 2010, 07:22:20 PM »
I've seen fresh bored sleeve bottoms not re chamfered, it would make it really tough installing if not addressed.
