Author Topic: HD studs in F2 engine  (Read 2330 times)
Offline voxonda
« on: April 25, 2010, 03:27:36 AM »
Hey guys, need some help here.
First time working with a F2 ('78) engine. Use to K2-K6 engines. When installing the HD studs cannot use the 4 o-rings(size 5.5x3) that are on the studs next to the oil return studs. #6 item on picture. The older engines do not have them.
Should I look for replacements or can I drop them?
Thanks, Rob
Online simon#42
  • liverpool
Re: HD studs in F2 engine
« Reply #1 on: April 25, 2010, 11:53:28 AM »
i didnt bother with them , in fact when i striped the engine  they were not there , i spoke to the previous owner and he told me the engine had never been apart . having seen that picture i was slightly concerned about oil leaks but its done 20,000 miles since then with no problems , did your engine have the o rings rob?
Offline voxonda
« Reply #2 on: April 25, 2010, 12:54:38 PM »
Hey Simon,
Yes, it did. But it wonders me what the function is of the rings. Think to avoid oil creeping up.
Thanks for your info,
Rob
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #3 on: April 25, 2010, 02:42:29 PM »
Both my '78K and '77F had them. I think my '77F Bike-in-a-box had them too. The F has an 836 kit though, so that might not be any indication. The K, however, is different. I am the documented third owner, and from what I saw, I am the only one to ever get in the engine, so they are "Fuctory" as a mechanic friend of mine would say.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline voxonda
« Reply #4 on: April 26, 2010, 01:45:46 AM »
Thanks Gonzowerke and Simon,
Did find some new Ø8 x 2.0 O-rings in my shop and will use these.
Cheers, Rob
Online simon#42
  • liverpool
« Reply #5 on: April 26, 2010, 10:33:50 AM »
hi rob , i was going to do something similar but [ from my poor memory ] i think they interfered with the base gasket , i am well aware that you know your stuff , but just check please!
Offline voxonda
« Reply #6 on: April 26, 2010, 10:58:34 AM »
Hey Simon,
Found o-rings in my shop, both Ø7x2 and Ø8x2. Using the Ø7x2 fills up the taper of the block and doesn't interfere with the basegasket. The Ø8 are a bid 'sloppy' around the studs.
Will let you know how it works once I mounted and started the engine.
Cheers, mate.
Online simon#42
  • liverpool
« Reply #7 on: April 26, 2010, 12:35:16 PM »
thanks
Offline brandEn
« Reply #8 on: March 29, 2011, 02:43:34 AM »
Hey Simon,
Cheers, mate.
Hey Rob, did you ever have any oil leaks? Getting ready to assemble my 836 and F3 head and wondering about those o-rings.
Offline voxonda
« Reply #9 on: March 29, 2011, 05:06:35 AM »
Hey BWJ,
No oilleaks what so ever. Engine as dry as the clutch it has. ;)
Cheers, Rob
Offline brandEn
Re: Re: HD studs in F2 engine
« Reply #10 on: March 29, 2011, 06:15:46 AM »
Thanks! Now hopefully no leaks for me.
