Author Topic: F&K rear hubs  (Read 1948 times)
Offline maksuttt
F&K rear hubs
« on: January 27, 2006, 04:12:57 AM »
Hi!
Does anyone know, CB 750 F&K rear hubs have same dimensions (diameter, etc, exept brake system)?
Thank you!
« Last Edit: January 27, 2006, 12:05:12 PM by maksuttt »
CB-750F 1975
My gallery is here
My blog is here
Offline maksuttt
Re: F&K rear hubs
« Reply #1 on: January 30, 2006, 03:49:35 AM »
Ok. May be i can ask question in different way: don't rear spokes from 750 K&F models have same size?
Thank you!
CB-750F 1975
My gallery is here
My blog is here
Jim Shea
Re: F&K rear hubs
« Reply #2 on: January 30, 2006, 04:02:10 AM »
As far as I know the rear wheels are almost identical?
Offline 78 k550
Re: F&K rear hubs
« Reply #3 on: January 30, 2006, 07:46:56 AM »
I just replaced an 77 550F hub and tire on my 72 500 The hub is a little wider and had to get a wheel spacer from a 750 to line up the sprockets. I thought the F's  had mags and the K's had spoke's
Paul
« Last Edit: January 30, 2006, 07:50:23 AM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Jim Shea
Re: F&K rear hubs
« Reply #4 on: January 30, 2006, 09:45:58 AM »
Only the F2 & 3 had Comstar, the F1 had spokes..
Re: F&K rear hubs
« Reply #5 on: January 30, 2006, 11:41:40 AM »
All I can add here is that the rear brake unit for the 78 will fit into the hub of a K bike (in my case a 1972). I just did this at the weekend.
Cheers
Andy in Boston
Offline Clyde
Re: F&K rear hubs
« Reply #6 on: January 30, 2006, 06:19:08 PM »
Spoke sizes between the drum and disc hubs are slightly different (about 2mm from memory)
Buchanan's supply the same spoke set for both wheels, but cunningly use a slightly longer nipple than standard to get over the problem.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline mrbreeze
  • Not your average
Re: F&K rear hubs
« Reply #7 on: January 30, 2006, 08:48:11 PM »
longer "NIPPLE"!!!!!
MEMBER # 257
Offline maksuttt
Re: F&K rear hubs
« Reply #8 on: January 31, 2006, 04:13:36 PM »
Thank you!
Will try to lace...
CB-750F 1975
My gallery is here
My blog is here
Offline KB02
Re: F&K rear hubs
« Reply #9 on: February 01, 2006, 06:16:16 AM »
The difference being the K's had Drum brakes and F's had Disk brakes.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
