Author Topic: permanent removal of headlight- where to put all the wiring?  (Read 761 times)
birdy
« on: April 26, 2010, 02:08:18 AM »
Like the look, so I'm thinking of running with no headlight...
Here in UK it is legal as we can run 'daylight only' paperwork. Trouble is, is there a neat way of locating all the electric stuff that is crammed into the headlight shell?
Offline HondanutRider
Re: permanent removal of headlight- where to put all the wiring?
« Reply #1 on: April 26, 2010, 04:47:19 AM »
On my "dirt bike" - a 1972 SL100, I removed the headlight 'cause the shell was all busted.  The fork ears got turned-in and tie-wrapped together so that the orange side-reflectors mounted on them point forward.  Then the wires were coiled and wrapped in a section of inner tube that was also tie-wrapped around the bundle of wires, positioned behind the ears that now fit together.  Any exposed wire-ends were taped over to insulate.
I also removed the brake light 'cause that came with a missing lens.
Offline BurtonWarpup
« Reply #2 on: April 26, 2010, 07:58:07 AM »
I'm sort of in the same situation. I'm putting a Dyna / Sportster front end on my 750 that has a smaller 4" headlight with no extra room for wiring. I was thinking of using a fork bag to store it all in, as it would go with the look i'm after. I'm not sure that that would work for you though...
Mike
1.5x 1974 CB750K4
2003 Triumph Speedmaster
http://flickr.com/photos/mikepark/
"Now, with a hundred miles on the clock, the rider has nearly forgotten what it means to sit anywhere but on this machine." -Melissa Holbrook Pierson
Offline Alan F.
« Reply #3 on: April 26, 2010, 09:43:14 AM »
It would seem that some sort of a junction box would be required unless you were to do away with the connectors all together by splicing and insulating the connections, that way you could simply wrap the harness in black tape and call it a day.
What do race bikes without headlights do?
Offline Thunder
« Reply #4 on: April 26, 2010, 03:00:59 PM »
Put em in a fake toolbag?
Offline the architect
« Reply #5 on: April 27, 2010, 06:28:50 AM »
For what it's worth, I just finished rewiring my bike from scratch.  All my electronics (battery, starter solenoid, ignition, regulator, rectifier, etc) now live in a shallow tray beneath my seat.  All the wiring (including two new relays for the headlight) is located on the frame, wrapped in weather-proof sheathing.  The only thing in my headlight bucket is the headlight plug, and it can be quick-disconnected.
It can be done.  It just depends on your motivation and patience  ;)
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
