Author Topic: CB550 Valve cover removal in frame  (Read 3457 times)
kabuki
« on: April 26, 2010, 12:43:01 PM »
Can it be done?
I'd like to replace my badly leaking valve cover o-ring, but if the whole motor has to come out, I may re-think this one...
Thanks,
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: CB550 Valve cover removal in frame
« Reply #1 on: April 26, 2010, 12:49:39 PM »
It can be done, easily.
No need to remove the engine.
Bikes parked out front mean good chicken-fried steak inside.
kabuki
« Reply #2 on: April 26, 2010, 12:56:07 PM »
Easily sounds good. Thanks,
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #3 on: April 26, 2010, 01:52:32 PM »
psssst.  don't for get the rubber bands on install (need to hold the rockers up from the valve tips).
searching for a dr350se
Offline Ayrity
« Reply #4 on: April 26, 2010, 02:46:36 PM »
where do the rubber bands go? surely i could just screw out the tappets so they dont hit the valve stems upon installation?
1976 Honda CB550k
Offline Brian G
« Reply #5 on: April 26, 2010, 02:55:20 PM »
Yes, it is possible do it without the rubber bands - I also just backed off the adjustment screws all the way and was then very careful to make sure the rockers were in the correct position as I lowered the cover into place. If you feel any resistance at all, take a closer look!
Hth,
Brian
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: April 26, 2010, 03:04:02 PM »
With special thanks to Jonesy!
http://forums.sohc4.net/index.php?topic=17364.msg179562#msg179562
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Ayrity
« Reply #7 on: April 26, 2010, 03:27:20 PM »
amazing thanks!!!
1976 Honda CB550k
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #8 on: April 26, 2010, 09:47:35 PM »
This place & you fellas never cease to amaze me. How simple is that?
Just shows you can learn something new every day. Cheers.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
