Author Topic: lost carb part  (Read 972 times)
mfhutchins
lost carb part
« on: April 26, 2010, 04:56:30 PM »
i just finished soaking all 4 carbs in carb cleaner and reassembled them.  i realized on the last carb that i am missing a small solid metal rod piece that is concave on both ends.  it fits in what is called the throttle slide arm assembly.  i went to crotchrocket.com and found the part and it says its not available.  any ideas on what i should do now?
i am a week or 2 from having this 550 on the road and losing a tiny part like this has me really frustrated.  i kept everything in egg crates and havent figured out how i lost it but thats water over the dam.
Offline Elkie
Re: lost carb part
« Reply #1 on: April 26, 2010, 05:02:18 PM »
What model 550 carbs do you need the part for, and can you get a pic of the part.
mfhutchins
Re: lost carb part
« Reply #2 on: April 26, 2010, 05:05:42 PM »
oh, sorry.  its a 76 550F super sport 4 into 1 exhaust.
Offline theofam
  • I'm cold, give me a
  • Suffering from MDD - Mechanical Deficit Disorder
Re: lost carb part
« Reply #3 on: April 26, 2010, 09:06:56 PM »
Is it this?
If so, PM me.
If not, can you point us to a manual's photo/link?
Offline fastbroshi
  • Puppet
Re: lost carb part
« Reply #4 on: April 26, 2010, 09:16:31 PM »
If not that is it the longer one with the holes going down the length of it?
Just call me Timmaaaaay!!!
Re: lost carb part
« Reply #5 on: April 26, 2010, 09:19:20 PM »
Is it made of steel? If so, you might try fishing around in the can of carb cleaner that you soaked them in with a magnet.
Offline magconpres
Re: lost carb part
« Reply #6 on: April 26, 2010, 09:24:51 PM »
Are you talking about the part that is spring loaded (when assembled) and is "grips" that ball in the throttle linkage (I am assuming your carbs are set up similar to a CB400F).
If so, I bet you could make the part easy enough.  Take some rod that will fit in the linkage, cut to size, and ise a ball grinder on a Dremel to shape the ends a bit (make them concave) to wrap around the ball in the linkage.  Use another one as a pattern.
The part in the pic posted looks like the spring mount.  Not the same part, I think.
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
mfhutchins
Re: lost carb part
« Reply #7 on: April 27, 2010, 02:40:14 PM »
theofam - nope.  those look like jets.
fastbroshi - no.
scottly - i put a rubber glove on my hand and felt around the bottom.  i couldnt feel anything in there.  and i did it for about a minute.
magconpres - yes, it is that one!  i think your suggestion sounds doable for me.  im going to give that a try.  thanks. (sometimes it just takes someone else suggesting something you never thought of).  i was hoping for a spare part from someone's incomplete carb.
now ill head over to a metal parts supplier that im sure will have a length of rod i'll need.  il have to buy at least 2 feet of it im sure just to make a 1/2" part.  maybe ill make a few extras.
