Author Topic: Yet another Carb thread. Dialing in 750 carbs for a 650 bike.  (Read 833 times)
Offline manjisann
I have a '80 CB650 Custom that I put '74 750 Carbs on (bottle top ones). I got them from Soos a fellow forum member, cb650 guru and modder. He had them running on his '79 650 (His is bored out and has a port joby and he was using the stock air system, I'm using 2 into 1 K&N pods for fitment reasons on an otherwise stock engine). I put them on and synced them (after tuning everything else) and they were all pulling the same. So here's the question(s)
It runs fine while cold but once she warms up the throttle begins to act weird. Sometimes it won't pull past 5500 rpms no matter how much throttle I give. I'm pretty sure my fuel delivery is working (there is an inline filter, and before I get flamed for that, there is no tank filter due to fitment reasons). It starts to bog down and blubber. I'm pretty sure it's way too rich, seeing as how the carbs were meant for a 750. Sometimes it won't want to idle properly either. Neither of these problems are so consistent that I can always replicate them, but I can guarantee they'll happen once it warms up (hopefully that makes sense). Soos suggested that I adjust the needles one notch leaner as well as fiddle with the pickups (advancer?). I removed, cleaned and lubed my advancer and turned it clockwise a wee bit and that seems to have helped some with the idle (before doing this it wouldn't idle while warm unless the idle screw was turned in until it idled at 2500 rpms or more.)
I'm trying to formulate a plan of attack since I'm doubting that adjusting just the needle will fix the problem, though that would be nice. Any suggestions?
Thank
Brandon
1980 CB650 Custom
Re: Yet another Carb thread. Dialing in 750 carbs for a 650 bike.
« Reply #1 on: April 26, 2010, 07:24:46 PM »
what do the plugs look like?
Offline manjisann
« Reply #2 on: April 26, 2010, 07:49:09 PM »
Black and sooty. The plugs are pretty new, the caps are new as are the wires.
Brandon
1980 CB650 Custom
Offline weltzing
« Reply #3 on: April 28, 2010, 12:07:45 PM »
i was going to do the same thing put 750 carbs on my 650 but from hearing all these problems i just dunno if i want to do that now.  the only thing i could think of as i was told was to use bigger fuel jets because it others always ran too lean...
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #4 on: April 28, 2010, 12:51:43 PM »
Maybe try warming the bike up and trying to recreate that blubbering at 5-6k where it just won't pull past 5-6k. When that starts to happen pull the clutch in and hit the kill switch at the same time. Coast in NEUTRAL to your garage and pull the plugs. That should tell you what caused it not to run past 5-6k.
Im working on a 1979 Suzuki 425 that has the exact same problem your describing. I've dipped the carbs and changed out the air filter and the problem is still there! I'm pretty confident that I've ruled out my carbs. Just take it one step at a time an start ruling out different parts 100%.
Its hard to be wrong when you know nothing!
